2013 International 4300 – Dump Truck with Crane
Posted Date: Aug 5th, 2025 at 04:53 AM
0.0 star 145 views
Price: $68840.00
Heavy-Duty | Versatile | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: International 4300
  • Year: 2013
  • Engine: [Confirm – likely International MaxxForce or Cummins diesel] powerful and reliable
  • Transmission: [Confirm – Eaton Fuller manual or Allison automatic]
  • Drive: Heavy-duty vocational chassis, often 4x2 or 4x4 configuration
  • GVWR: High-capacity rating for dump and crane operations
  • Cab: Day cab with comfortable driver seating, A/C, and ergonomic controls
🔧 Dump Body Specifications:
  • Type: Heavy-duty dump bed designed for construction materials, debris, and bulk hauling
  • Capacity: [Confirm cubic yards or tonnage]
🔧 Crane Specifications:
  • Type: Hydraulic truck-mounted crane
  • Max Lifting Capacity: [Confirm – typically in the 10,000–20,000 lb range depending on model]
  • Boom Reach: [Confirm – often 30–50+ ft horizontal reach]
  • Controls: Hydraulic controls with manual or remote operation
  • Versatile International 4300 chassis built for heavy-duty dump and crane applications
  • Powerful crane for material handling and placement
  • Durable dump body for efficient hauling and unloading
  • Outriggers for stable crane operation
  • Comfortable cab for long workdays
  • Maintained and ready for immediate work
  • Construction and site cleanup
  • Material delivery and placement
  • Utility and municipal service
  • Industrial hauling and lifting
