2012 Western Star – Truck-Mounted Knuckle Boom Crane
Posted Date: Aug 5th, 2025 at 04:56 AM
0.0 star 157 views
Price: $124000.00
Heavy-Duty | Versatile Lifting | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: Western Star
  • Year: 2012
  • Engine: [Confirm – likely Detroit Diesel or Cummins engine] powerful and reliable
  • Transmission: [Confirm – Eaton Fuller manual or Allison automatic]
  • Drive: Heavy-duty vocational chassis, typically 6x4 or similar configuration
  • GVWR: High-capacity vocational rating to handle heavy crane loads
  • Cab: Day cab with premium seating, ergonomic controls, and comfort features
🔧 Crane Specifications:
  • Type: Hydraulic articulating knuckle boom crane
  • Max Lifting Capacity: [Confirm – typically 15,000–30,000 lbs depending on crane model]
  • Boom Reach: [Confirm – usually 40+ ft horizontal reach]
  • Controls: Hydraulic controls with manual or remote operation for precise handling
  • Robust Western Star chassis designed for heavy-duty vocational applications
  • Versatile knuckle boom crane for precise lifting and placement in tight spaces
  • Outriggers for stable and safe lifting operations
  • Spacious, comfortable cab for operator efficiency
  • Maintained and ready for immediate deployment
  • Construction and material handling
  • Utility and municipal services
  • Industrial lifting and transport
  • Heavy-duty crane operations
