2012 International 7400 – Altec Crane with Digger (Tandem Axle)
Posted Date: Aug 5th, 2025 at 04:41 AM
Price: $63830.00
Heavy-Duty | Pole Setting | Work-Ready Unit
🔧 Truck Specifications:
Make/Model: International 7400
Year: 2012
Engine: [Confirm – likely International MaxxForce 9/10 or Cummins ISL] high-torque diesel engine
Transmission: [Confirm – Eaton Fuller manual or Allison automatic]
Drive: Tandem axle heavy-duty vocational chassis – excellent for crane and auger operations
GVWR: High-capacity vocational rating for crane and digger use
Cab: Day cab with premium driver’s seat, ergonomic controls, A/C, and comfort features
Mileage: [Insert mileage if known]
🔧 Crane & Digger Specifications:
Brand/Model: Altec [Insert exact model if known]
Type: Hydraulic crane with auger/digger attachment
Max Lifting Capacity: [Confirm – typically 15–25 ton range depending on model]
Boom Reach: [Confirm exact horizontal/vertical reach – approx. 40–60+ ft]
Digger/Auger: Hydraulic auger for drilling and pole setting operations
Controls: Hydraulic controls and/or remote operation for precision handling
Condition: Fully operational, well-maintained, work-ready
Rugged International 7400 tandem axle chassis for maximum stability and durability
Altec crane with integrated digger – perfect for utility, telecom, and construction work
Outriggers for excellent stability during lifting and drilling
Versatile setup – dig, lift, and place poles or heavy materials with one unit
Spacious, comfortable cab with driver-focused controls
Maintained and ready for immediate service
Utility pole setting and replacement
Electrical and telecom construction
Oilfield and industrial service work
General construction lifting and drilling applications
