2007 Sterling – Crane Truck with CAT C-13
Posted Date: Aug 5th, 2025 at 04:42 AM
0.0 star 181 views
Price: $49900.00
Heavy-Duty | Reliable Power | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: Sterling
  • Year: 2007
  • Engine: Caterpillar C-13 diesel – strong, high-torque performance for heavy lifting and hauling
  • Transmission: [Confirm – Eaton Fuller manual or Allison automatic]
  • Drive: Heavy-duty vocational chassis built for crane operations
  • GVWR: High-capacity vocational rating to handle crane loads and cargo
  • Cab: Day cab with premium driver’s seat, ergonomic controls, A/C, and comfort features
🔧 Crane Specifications:
  • Brand/Model: [Insert specific crane make/model if known]
  • Type: Hydraulic truck-mounted crane
  • Max Lifting Capacity: [Confirm – typically in the 15–30 ton range depending on model]
  • Boom Reach: [Confirm exact reach – often 60–100 ft depending on model]
  • Controls: Hydraulic controls and/or remote operation for precision handling
  • Condition: Fully operational, well-maintained, ready to work
  • Powerful CAT C-13 diesel for dependable performance and long service life
  • Heavy-duty Sterling chassis designed for stability under crane operations
  • Outriggers for superior stability and safety during lifts
  • Spacious, comfortable cab for operator efficiency
  • Large deck space for tools, equipment, and cargo
  • Maintained and ready for immediate work
  • Construction lifting and material handling
  • Utility and municipal service
  • Oilfield and industrial lifting applications
  • General heavy-duty crane work
