2007 International Crane Truck – Pre-Emissions Powerhouse
Posted Date: Jul 9th, 2025 at 05:21 AM
0.0 star 198 views
Price: $79900.00
🚛 2007 International Crane Truck – Pre-Emissions Powerhouse
Durable | Simple | Work-Ready – Ideal for Drywall, Roofing, or Material Delivery
🛠️ Truck Specifications – 2007 International (Pre-Emissions)
  • Engine: International DT466 – Legendary reliability, mechanical simplicity, and easy maintenance
  • Transmission: 6-Speed Manual (or Allison Automatic, depending on unit) – Smooth power delivery and easy to repair
  • Mileage: Low miles for the year – fleet-maintained and regularly serviced
  • GVWR: 33,000 lbs – Non-CDL option available depending on configuration
  • No DPF, No DEF, No EGR – 100% Pre-Emissions unit: less downtime, fewer costly repairs, no regen cycles
  • Cab Features:
    • Bench or air-ride bucket seat options
    • Manual climate controls
    • Durable, easy-clean vinyl interior
    • Clear dash, no warning lights
  • Clean title – Fleet-maintained, no accidents
🏗️ Crane System – Drywall or Material Handling Boom
  • Make/Model: Varies (e.g., National, Hiab, Palfinger, Fassi) – Confirm brand on inspection
  • Lifting Capacity: Typically 4,000 – 6,000 lbs depending on boom model
  • Reach: Approx. 40–60 ft horizontal reach (dependent on extension and model)
  • Boom Style: Knuckle or stick boom (confirm specs on unit)
  • Rotation: 360° manual or hydraulic rotation for easy access to multi-story buildings
  • Controls: Side-mounted levers or wireless remote (if equipped)
  • Stabilizers: Hydraulic outriggers for safe, level operation on uneven ground
📦 Flatbed / Drywall Body Configuration
  • Body Length: Usually 20–24 ft steel or aluminum bed
  • Drywall Rack System: Upright removable stakes and tie-down system for secured loads
  • Rear Access: Forklift-ready with open rear or optional liftgate
  • Deck Condition: Clean, solid, with anti-slip coating and multiple D-rings
🔧 Key Benefits
  • Pre-Emissions = Less Maintenance, Lower Costs – No DEF, no DPF, no sensors to fail
  • Strong, simple mechanics – Perfect for mechanics or owner-operators
  • Budget-friendly alternative to new units – Save thousands with proven durability
  • Ideal for:
    • Construction supply delivery
    • Roofing and framing contractors
    • Lumberyards and drywall distribution
    • Equipment rental fleets
  • Turnkey Ready – Fully operational and DOT-compliant
🧾 Additional Info
  • Financing available (OAC) – Nationwide delivery options
  • Title: Clean title, no liens
  • Pricing: Competitively priced for fast sale – Contact for exact specs and quote
💡 Why Buy a Pre-Emissions Unit?
  • No computer diagnostics needed – Easy to maintain and troubleshoot
  • More uptime, fewer breakdowns – Proven performance in rough conditions
  • Great for export or off-road industrial use
  • Perfect fleet backup or entry-level crane truck
