2006 Grove RT700E 4x4x4 Rough Terrain Crane
Posted Date: Aug 16th, 2025 at 02:50 AM
Price: $162500.00
π§ 2006 Grove RT700E 4x4x4 Rough Terrain Crane - Ready for the Toughest Jobs! π§
Are you in need of a reliable and powerful crane that can handle the most challenging terrains? Look no further! Our 2006 Grove RT700E 4x4x4 Rough Terrain Crane is a robust workhorse designed to elevate your projects to new heights. ποΈ
π Key Features:
- 4x4x4 Drive: Exceptional maneuverability on any terrain, ensuring you can get to those hard-to-reach places with ease.
- 70-Ton Capacity: Capable of lifting heavy loads, providing you with the versatility needed for various tasks.
- 33-105 ft Boom Length: Reach greater heights and distances without compromising on stability or safety.
- Powerful Cummins Engine: Reliable performance that delivers power when you need it most.
- Operator-Friendly Cabin: Comfortable and intuitive controls make it easy for operators to work efficiently and safely.
- Advanced Safety Features: Stay secure with state-of-the-art safety systems designed to protect both your crew and equipment.
π§ Perfect For:
Whether you're working in construction, oil and gas, or maintenance industries, the Grove RT700E is equipped to meet your needs. From lifting heavy materials on construction sites to assisting in infrastructure projects, this crane is your go-to equipment for efficiency and reliability. π
Why Choose Our Crane?
Invest in a machine that combines strength, reliability, and flexibility. Our Grove RT700E isn't just a crane; it's a partner in your success, ensuring every lift is performed with precision and safety. π‘οΈ
Don't miss out on the opportunity to enhance your operations with this incredible piece of machinery. It's time to lift your productivityβliterally! π
Contact us today to learn more and schedule a viewing. Your next big project deserves the power of the Grove RT700E!
