2004 Broderson IC-200-2F – Carry Deck Crane with Current NDT & Real-Time Monitoring
Posted Date: Aug 3rd, 2025 at 07:33 AM
0.0 star 140 views
Price: $58500.00
Well-Maintained | Certified | Compact & Versatile
🔧 Crane Specifications:
  • Make/Model: Broderson IC-200-2F
  • Year: 2004
  • Capacity: 15 tons (30,000 lbs)
  • Boom Length: ~50 ft three-section hydraulic boom
  • Jib: Optional 15 ft jib (if equipped)
  • Max Tip Height: ~65 ft with jib
  • Engine: Cummins or GM gas/LPG (confirm installed option)
  • Transmission: Powershift
  • Drive: 4x4 steering (four-wheel steer for tight job sites)
  • Hours: [Insert if known]
  • Current NDT certification – meets safety and inspection requirements
  • Real-time crane monitoring system for enhanced operator safety and efficiency
  • Compact carry deck design – ideal for tight spaces and industrial work
  • Rugged construction with smooth hydraulic operation
  • 360° continuous rotation for maximum versatility
  • Outriggers for stable lifting on uneven ground
  • Well-maintained and fully work-ready
  • Industrial plants and manufacturing facilities
  • Maintenance and material handling inside warehouses
  • Construction and utility work in confined spaces
  • Machinery installation and removal
