2002 Peterbilt 330 – Single Axle – 27' Flat Deck – 4,000 lb Power Tailgate 6-Speed Manual Transmission - Air Ride - Cummins Engine
Posted Date: Feb 15th, 2026 at 06:23 PM
5.0 stars 236 views
Price: $16000.00
2002 Peterbilt 330 – Single Axle – 27' Flat Deck – Power Tailgate
Well-maintained and ready to work.
Specifications & Features:
  • Single Axle
  • 27' Flat Deck
  • 4,000 lb Power Tailgate
  • 6-Speed Manual Transmission
  • Cummins Engine  -   Engine size: 8.3 - 300 HP
  • Fuel: 7-10 mile p/g
🔧 Engine Overview — Cummins 8.3 L ISC
The Cummins ISC 8.3 L inline-6 turbo diesel was a common engine in medium-duty trucks like the Peterbilt 330 in the early 2000s. It’s known for a strong torque curve and durability in vocational use (e.g., roll-off, box truck, utility bodies).
📊 Typical Power & Torque (Approximate)
  • Horsepower: ~275 hp to 300 hp commonly found in 2002 Peterbilt 330 specs
    (Many trucks from that year were spec’d ~300 hp from the factory.)
  • Torque: Around 900–950 lb-ft (depending on tune and CPL code)
Cummins ISC 8.3 engines could be rated anywhere from about 250 hp up to 400 hp in various applications, but medium-duty truck builds like the Peterbilt 330 most commonly sit in the 275–300 hp range.
  • A/C
  • Tilt Steering Wheel
  • Cruise Control
  • Air Horn
  • Peterbuilt Air Ride c/w Dump Valve
  • Cummins Diagnostic & Idle Control
Mileage: 304,372 km
Condition: Fresh Certification – Ready to Work
Frank 604-476-7777 Call or Text Or WhatsApp
Mileage 304,372 km
Transmission Manual
Location Sumas Fraser Valley
Color White
Condition Refurbished
Year 2002
Fuel Type Diesel
Drive / Axle Configuration 4x2
Body Length 24
Lift Gate Yes
Mark Henry Feb 23rd, 2026 at 06:55
I bought the 2002 Peterbilt 330 Single Axle with 27′ Flat Deck, 4,000 lb Power Tailgate, 6-Speed Manual Transmission, Air Ride, and Cummins Engine from Alltrac, and I’m extremely satisfied with both the truck and the buying experience. This Peterbilt is a rugged, reliable workhorse — the Cummins engine runs strong, the manual transmission shifts smoothly, and the flat deck with power tailgate makes hauling equipment and materials so much easier. It’s obvious this truck was well looked after and ready to go to work when I picked it up. The entire process with Alltrac was professional and straightforward. Communication was clear, questions were answered quickly, and the truck arrived exactly as described. Alltrac made the transaction smooth and stress-free. I highly recommend this truck and Alltrac as a trusted seller. Very happy with my purchase and would definitely do business with them again!
Feb 18th, 2026 at 23:20
FIVE STAR !!!!! 2002 Peterbilt 330 – Single Axle – 27' Flat Deck – 4,000 lb Power Tailgate 6-Speed Manual Transmission - Air Ride - Cummins Engine
