HILTI PR 30-HVS A12 OUTDOOR ROTATING DUAL SLOPE LASER LEVEL
Apr 28th, 2024 at 00:15 Construction / Logging Willoughby 83 views Reference: 611Location: Willoughby
Price: $1,200 Negotiable
In the fields of construction and surveying, the Hilti PR 30-HVS A12 is more than just a tool—it'sa revolution. With the help of this powerful outdoor rotating laser level, you can work with greater accuracy and efficiency.
Unrivaled Precision
With an unmatched accuracy of ±0.02 in at 33 ft¹, the Hilti PR 30-HVS A12 guarantees that your measurements are exact to the very last millimeter. This degree of precision is essential for jobs like formwork, concrete pours, and excavation that call for precise measurements.
Broad Operational Spectrum The Hilti PR 30-HVS A12 is reliable for both small-scale projects and large-scale construction sites. This tool's operating range spans from 7 to 1640 feet in diameter1, making it capable of handling any task you throw at it.
Secure and Adherent Laser Class Safety is Hilti PR 30-HVS A12's first priority. The majority of construction and surveying applications can safely use the laser due to its Class II (FDA CFR 21 art. 1040), Class II (EN 60825), and < 4.85 mW output at 620-690 nm.
The Auto-Alignment Function Embrace the convenience of automatic alignment. Even from up to 490 feet away, one person can quickly and easily align your rotating lasers thanks to the auto-alignment feature1. By saving you time and effort, this feature lets you concentrate on other crucial project components.
Inclination Alignment and Digital Slope Entry The digital slope entry and inclination alignment features simplify grading tasks1. These features make it simple to establish and maintain slopes, which simplifies difficult tasks like building ramps and parking lots.
Platform for Cordless Batteries The Li-ion batteries used by the Hilti PR 30-HVS A12 are identical to those used by all other 12V Hilti power tools1. With a 35-minute charging time, these batteries guarantee that your tool will always be ready for use.
Constructed to Last The hardest jobsite conditions are designed to be withstood by the Hilti PR 30-HVS A12. It has four shock-absorbing handles, IP66 protected housing, head-mounted bumpers, and is engineered to meet US Military standards (MIL-STD-810G). Your tool will remain accurate and functional even in challenging circumstances thanks to its sturdy construction.
Hilti's Outstanding Assistance When you buy the Hilti PR 30-HVS A12, you're investing in a service as well as a tool. Hilti provides a 20-year product warranty against defective parts and manufacturing flaws1. Repair expenditures are capped after two years. To save downtime, they also offer loan tools while repairs are being made.
HILTI PR 30-HVS A12 OUTDOOR ROTATING LASER LEVEL
Outdoor rotating laser level with automatic vertical alignment and dial-in slope functions
Accuracy: ±1/32 in at 33 ft
Operating range with laser receiver (diameter): 7 - 1640 ft
Laser class: < 4.85 mW, 620-690 nm, Class 2 (EN 60825), Class II (FDA CFR 21 art. 1040)
From $2,597.00 BARE LASER WIH CASE INCLUDED
COST WITH ALL ATTACHMENTS IS $3289.00
TAKE THIS LOW HOUR UNIT READY WORK C/W ALL PIECES SHOWN FOR $1200.00
ONLY SELLING AS LEAVING BC - UNIT LITTLE USED AND WELL LOOKED AFTER
View full product list (2)
FEATURES & APPLICATIONS
Features
When used with the PRA 30 remote control/laser receiver, the Hilti PR 30-HVS rotating laser is a complete, more reliable outdoor layout tool for virtually any leveling, aligning and squaring tasks
Built to maintain laser accuracy in rough jobsite conditions – engineered to US Military standards (MIL-STD-810G) with head-mounted bumpers, four shock-absorbing handles and IP66 protected housing
Cordless battery platform – uses the same Li-ion batteries, which charge with 35 minutes, as all your other 12V Hilti power tools
Auto-alignment – makes aligning your rotating lasers a fast, one-person task even from up to 490 ft. away
Digital slope entry and inclination alignment (e-targeting) simplify grading tasks
Applications
Horizontal leveling – formwork, concrete pours, excavation, etc.
Vertical aligning – transferring building lines, aligning columns, façades
Slope / inclination grading – ramps, parking lots, pipes
Squaring – formwork
TOOL WARRANTY
Warranty redefined.
We stand behind our customers, and the quality of our tools, with an industry leading service promise to match. Which is why we offer two years of wear and tear coverage with parts, shipping, and labor on us. And we know a tool repair means unproductive downtime - which is why we promise one day turnaround in our repair centers to get you back up and running with limited interruption.
20 YEAR
Materials and workmanship warranty
Hilti will repair or replace parts that break as a result of defects in materials or workmanship for 20 years.
