EXTREME DUTY 6O FT LONG REACH PC450LC DEMOLITION HAMMER-GRAPPLE
May 14th, 2023 at 04:06 Excavators Langley 665 views Reference: 158Location: Langley
Price: $500,000 Negotiable
SHEET PILE DRIVER - EXCAVATION - DEMOLITION EXCAVATOR - 7200 HOURS
SEE COMPLETE DETAILS AND PICTURES OF THIS MACHINE HERE: (copy and paste web link)
https://www.ritchielist.com/construction/excavators-tracked-excavator/komatsu-pc-450-lc-8/dd305d29-f3e8-47bf-b084-4e4521014a43.html
FOR SALE C/W WITH THE NEW 2021 175 HYDRAULIC HP HYDRARAM SHEET PILE DRIVER WORTH OVER $250.000.00 FOR $500.000.00
WE ARE INTO THIS BASE MACHINE FOR WELL OVER $600,000.00 AND TWO YEARS OF BUILD
TO REPLACE TODAY WOULD BE OVER 1.3 MILLION AND TAKE WELL OVER A YEAR TO BUILD
OR TAKE THE MACHINE C/W WITH 1 NEW HD 60 INCH HEAVY DUTY DIGGING BUCKET FOR $400,000.00
WE BUILT THE MACHINE TO REPLACE CRANES FOR SHEET PILE WORK WHICH ARE USELESS IN TIGHT LOCATIONS OR SWAMPY AREAS WITHOUT EXPENSIVE ACCESS ROADS NEEDED AND THEN REMOVED AT GREAT COST - PLUS THEY ARE NOT ABLE TO DO ANY OTHER WORK ON THE SITE - THIS MACHINE CAN DO IT ALL
CUSTOM NEW ALL KOMATSU 60-FOOT REACH 3-PIECE BOOM FOR LARGE HAMMERS - DEMOLITION PROCESSORS - GRAPPLES - GRAPPLE BUCKETS ETC - THIS MACHINE CAN DO EVERYTHING ON THE JOBSITE INCLUDING DIG 30 FEET DEEP
THE PROJECT DETAILS AND OBJECTIVES - TO BUILD AN EXCAVATOR THAT CAN:
1) DRIVE 40 - 50 -60 FOOT SHEET PILES WITH 175 HYDRAULIC HP SHEET HYDRA-RAM SHEET PILE DRIVER
2) USE LARGE 12000 FT LB HYDRAULIC HAMMERS - LARGE DEMOLITION PROCESSORS - STEEL SHEARS AT CONTACT POINTS OF UP TO 70 FEET BOTH VERTICAL AND HORIZONTAL
3) EXCAVATE WITH UP TO 2.5 YARD BUCKETS WITH BOTH A VERTICAL AND HORIZONTAL REACH OF 70 FEET TO A STRAIGHT WALL HEIGHT OF 70 FEET OR TO A DEPTH OF OVER 30 FEET:
4) TO USE A LARGE DUAL DRUM GRINDER TO A HEIGHT OF 70 FEET AND TO A DEPTH OF OVER 30 FEET
5) THAT HAS A TOTAL WEIGHT OF LESS THAN 110,000 LBS AND LOADED HEIGHT OF LESS THAN 14 .2 FEET SO AS TO BE MOVED ON A 8 AXLE LOW BED LEGALLY IN ONE PIECE
TO ACCOMPLISH THIS REQUIRED:
1)LOCATED A LOW-HOUR PC450LC-8 KOMATSU PRE-EMISSIONS MACHINE C/W DEMOLITION GUARDING AND DEMOLITION HYDRAULIC REMOVABLE ($50,000.00 OPTION) COUNTERWEIGHT AND NEW KOMATSU FACTORY HYDRAULIC PUMPS
2) TRANSPORT THIS CALIFORNIA MACHINE TO CHARLIE SMITH MACHINE FACILITY LANGLEY BC WAS THE ONLY SHOP THAT HAD BOTH THE ENGINEERING AND NECESSARY EQUIPMENT AND SKILL TO BUILD THIS
MACHINE TO MY SPECIFICATIONS
3) LOCATE - PURCHASE AND TRANSPORT A NEW KOMATSU-BUILT PC390-11 LOG LOADER BOOM C/W ALL HYDRAULIC CYLINDERS - GUARDS ETC TO CHARLIE SMITH MACHINE
THIS WAS REQUIRED AS NO STANDARD EXCAVATOR CONFIGURATION CAN EXTEND VERTICAL TO THE REQUIRED HEIGHT - OR HAVE THE LIFT CAPACITY SUPPLIED BY THE LARGER LOG LOADER BOOM CYLINDERS
AT CHARLIE SMITH MACHINE THE MACHINE HAD THE FOLLOWING MODIFICATIONS DONE:
1) CUSTOM MODIFIED THE NEW FACTORY KOMATSU LOG LOADER 2-PIECE BOOM TO A NEW CUSTOM 3-PIECE BOOM
TO DO THIS THEY REMOVED THE EXISTING PC450LC-8 STICK - THE EXISTING STICK AND BUCKET CYLINDER - COMPLETELY REBUILT - REBUSHED THEM - RE-PINNED THEM AND MODIFIED THE LOG LOADER BOOM
TO ACCEPT THEM AS A THIRD MEMBER STICK
2) INSTALL A AS NEW GEITH HYDRAULIC PIN GRABBER COUPLER WHICH ALLOWS FOR THE CHANGE OF ATTACHMENTS IN MINUTES HYDRAULICALLY
3) INSTALL ALL-NEW HYDRAULIC HARD STEEL LINES AND SOFT LINES ON COMPLETE BOOM - REQUIRED VALVES - JOYSTICK AND FOOT CONTROLS FOR THE THIRD STICK AND 3 HYDRAULIC FUNCTIONS PLUS CASE DRAIN
NOTE: With regards to the work done by Charlie Smith Machine, I supplied the NEW FACTORY Komatsu Log Loader Boom - All Hydraulic Valves and Hydraulic Hoses and Steel Lines - The Geith Coupler and All Komatsu Required Parts.
Their bill came to over $200,000.00
They do fantastic work but are not cheap but I was not after cheap I wanted it done right and was the only shop that I felt had the engineering ad could do the job the way it should be done.
THE MACHINE WAS THEN MOVED TO SMS EQUIPMENT LANGLEY BRANCH WHERE:
1) THEY COMPLETELY REBUILT THE ENTIRE HYDRAULIC SYSTEM INCLUDING THE MAIN CONTROL VALVE - REPLACED ALL O RINGS SET ALL THE FLOWS AND PRESSURES FOR THE HYDRA-RAM SHEET PILE DRIVE FOR A TOTAL BILL OF OVER $75,000.00
2) COMPLETE NEW DELUXE GERMAN QUALITY AUTO GREASER SYSTEM WAS INSTALLED
THE MACHINE WAS THEN MOVED TO DC WELDING - LANGLEY:
WHO PROCEEDED TO INSTALL TWO CUSTOM COUNTERWEIGHTS THAT I HAD LOCATED THAT WERE CONFIGURED TO GO AROUND THE HYDRAULIC DROP COUNTERWEIGHT ONTO A CUSTOM 1 1/2 THICK PLATE THEY MOUNTED ON TOP OF THE
EXISTING DEMOLITION COUNTERWEIGHT AND HAD THEM SO THEY CAN BE EASILY REMOVED IF REQUIRED QUICKLY BY REMOVING A FEW SECUREMENT BOLTS.
MACHINE WAS JUST PROFESSIONALLY PAINTED BY NAHANNI TRUCK AND TRAILER WHO HAND SANDED THE MAIN BODY WITH QUALITY PAINT - JUST INSTALLING THE NEW DECAL KIT - IT IS READY TO WORK
I HAVE WELL OVER $800,000.00 INVESTED IN THIS TWO-YEAR BUILD
I LITERALLY WENT OVERBOARD AND GOT CARRIED AWAY ON MAKING SURE THIS WAS BUILT RIGHT
IT IS A UNIQUE ONE-OFF MACHINE THAT CAN DO EVERYTHING FROM SHEET PILE DRIVING TO EXCAVATING TO DEMOLITION ETC.
AND WOULD BE A VERSATILE ADDITION TO ANYONE'S EQUIPMENT LIST AS CAN BE USE FOR LARGE HYDRAULIC HAMMERS - LARGE HYDRAULIC DEMOLITION PROCESSORS - GRAPPLES - PLATE COMPACTORS - VARIOUS BUCKETS THAT CAN DIG TO 30 FEET DEEP AND EXTEND TO 60 FEET REACH - OVER 60 FEET HIGH ALL WITH ONE MACHINE - THIS IS NOT A FLIMSY WEAK BOOM
ALSO AVAILABLE IS A BRAND NEW 2021 175 HYDRAULIC HORSEPOWER HYDRARAM SHEET PILE DRIVER TO DRIVE SHEET PILE - H PILES ETC
CAN BE MOVED COMPLETE ON 8 AXLE LOW BED WITH IT SITTING AT TOTAL HEIGHT OF 14 FEET ON TRAILER
MACHINE COST TO REPLACE WELL OVER 1.3 MILLION AND WITH TODAY'S ISSUES MORE THAN 12 MONTHS OF PARTS AND WORK. TO BUILD
HAVE PROFESSIONAL APPRAISAL FOR $660,000.00 WITH SHEET PILE DRIVER - AVAILABLE IN PDF FILE UPON REQUEST - THIS WAS BEFORE THE NEW AUTO GREASER AND. AN ADDITIONAL COUNTERWEIGHT WAS INSTALLED.
THIS MACHINE COST ME OVER $800,000,00 AND TWO YEARS TO PUT TOGETHER - HAVE ALL THE BILLS - JUST FINISHED AND READY TO WORK.
CAN SHIP LOCALLY QUICKLY WE GET GREAT RATES AND SERVICE AND CAN MOVE THE MACHINE IN ONE PIECE - FOR HIGHWAY MOVES JUST DROP THE HYDRAULIC REMOVABLE COUNTERWEIGHT AND MOVE IN TWO PIECES WITH ALL ATTACHMENTS ON THE SECOND TRUCK
