CAT 300 CLASS 74 INCH CLEANUP C/W PINS BOLT ON CUTTING EDGE AND WMB 34 INCH 2 YARD DIGGING BUCKETS
May 7th, 2023 at 17:26 Excavators Langley 1.1K views Reference: 143Contact us
Price: Contact us Negotiable
AS NEW TAKE IT FOR 8K
THIS AS NEW LIGHTLY USED EXTREME DUTY BUCKET IS OVER 20K FROM CAT TAKE IT FOR 8K
BUCKET HAS 15.1/8 BETWEEN EARS ON 19.5 CENTER TO CENTER ON PINS
ALSO AS NEW WBM EXTREME DUTY 2 YARD 34 INCH TRENCHING BUCKET C/W PINS AND TEETH FOR UTILITY WORK
THE WBM IS SET UP WITH A AS NEW REAR 90 MM PIN (INCLUDED) AND IS BUSHED FOR A 90 FRONT PIN OR 100 MM FRONT PIN
ALL THESE BUCKETS CAN ALSO BE USED ON ANY PIN GRABBER THAT USES 100 MM FRONT PINS AND 90 OR 100 MM REAR PINS WITH 15.25 INCHES BETWEEN THE EARS SUCH AS 330 - 336 - 345 B LINKAGE ETC CAT
TAKE YOUR CHOICE OF BUCKETS FOR $8000.00 EACH
