Backhoe Bucket Attachment โ€“ Heavy-Duty Digging Power for Any Jobsite
Posted Date: Jul 13th, 2025 at 04:15 AM
0.0 star 114 views
๐Ÿ› ๏ธ Backhoe Bucket Attachment โ€“ Heavy-Duty Digging Power for Any Jobsite
Universal Fit | Rugged Build | Perfect for Trenching, Excavation & Utility Work
๐Ÿ”ง Attachment Overview
  • Product Type: Backhoe Bucket
  • Compatibility: Fits most standard backhoes and mini backhoes
  • Mounting: Pin-on or quick coupler (specify pin size and spacing)
  • Bucket Width: [Insert width โ€“ e.g., 12", 18", 24", or 36"]
  • Capacity: [Insert capacity โ€“ e.g., 0.25 โ€“ 0.6 cu. yd.]
  • Tooth Style: Replaceable, bolt-on bucket teeth (standard or tiger style)
๐Ÿ—๏ธ Key Features
  • Heavy-Duty Construction:
    • Built with high-strength steel for extended life
    • Reinforced side plates and cutting edges for extra durability
  • Optimized Digging Performance:
    • Ideal for trenching, digging footings, landscaping, and utility lines
    • Smooth interior for easy cleanout and efficient loading
  • Tooth Configuration:
    • Comes with 3โ€“5 bolt-on teeth (based on size) for superior ground penetration
    • Optional side cutters for added cutting power and edge protection
โœ… Ideal Applications
  • Trenching for electrical, plumbing, and irrigation
  • General excavation and site prep
  • Footing and foundation digging
  • Agricultural and rural work
  • Rental fleets and jobsite toolboxes
๐Ÿ“ฆ Condition & Specs
  • Condition: [New / Lightly Used / Used โ€“ insert actual condition]
  • Mount Specs: [Insert pin diameter, width between ears, and overall width if known]
  • Availability: In-stock โ€“ ready for pickup or shipping
๐Ÿ’ฐ Pricing & Delivery
  • Competitively priced โ€“ contact for quote based on bucket size
  • Discounts available for bulk orders or multi-size packages
  • Delivery available locally and nationwide
  • Custom buckets and coupler conversions available
๐Ÿ”ง Why Choose This Backhoe Bucket?
  • Built tough for real-world jobsite abuse
  • Compatible with a wide range of backhoe loaders (CAT, Deere, Case, New Holland, etc.)
  • Easy-to-replace teeth and maintain
  • A must-have for any backhoe operator or contractor
