ATO 3 Phase Soft Starters 10 hp to 800 hp
Posted Date: Mar 18th, 2026 at 03:56 PM
0.0 star 241 views
Price: $352.31
ATO soft starters are also widely used in the mining industry, where heavy machinery operates under harsh conditions. Equipment such as crushers, mills, and conveyors require reliable motor control to handle high loads and frequent starts. ATO 3 phase soft starters provide the necessary torque control while minimizing electrical and mechanical stress. Their robust design ensures reliable performance in dusty and high-temperature environments. With capacities from 10 hp to 800 hp, these devices can support large-scale mining operations. The ability to operate at different voltage levels further enhances their versatility, allowing them to be integrated into various mining systems worldwide.
In the oil and gas sector, ATO electronic soft starters are used to control motors in drilling rigs, pumps, and compressors. These applications demand high reliability and precise control to ensure safe and efficient operation. Soft starters reduce the risk of electrical disturbances and mechanical failures during startup, which is critical in hazardous environments. Their programmable features allow operators to adjust parameters to specific operational requirements. With voltage options ranging from 220V to 480V, ATO three phase soft starters can be deployed in both onshore and offshore facilities. Their ability to enhance equipment longevity and reduce downtime makes them a valuable asset in this industry.
