ALLU PM200 ROTARY DRUM SOILS-SLUDGE-COMPOST MIXING 200-350 CLASS EXCAVATOR
Posted Date: Dec 15th, 2025 at 12:39 AM
Price: $20000.00
The ALLU PM200 is a rotary drum mixing attachment for excavators in the 200-350 class, used for mixing soils, sludge, and compost.
It functions as a power mixer, converting a standard excavator into a soil improvement tool capable of mixing materials like clay, silt, and peat, and can be used with various binders like dry powder or wet grout. This attachment offers solutions for soil stabilization, remediation of contaminated soil, and creating hard surfaces.
Key features and uses
Versatile mixer: Transforms an excavator into a soil mixing unit for a wide range of materials, including contaminated soil, sludge, and soft soils.
Binder options: Can work with different binders, such as dry powder, wet grout, or even just air, to mix into the material being processed.
Excavator-powered: Uses the excavator's auxiliary hydraulic system and can achieve mixing depths of up to 3m / or 26 ft with extensions.
Applications: Used for soil stabilization, improving soil for foundations, remediation of contaminated soil, and more. It can also be used for creating things like cement surfaces by mixing cement slurry with other materials.
Technical features:
Includes an automatic torque adjustment system, rpm, and temperature sensors, which can be changed monitored from the excavator cabin with adjusting hydraulic flow.
Mounting: Typically mounted with 90mm pins and can be bushed down to 80mm to fit a range of excavators within the specified class.
Excavator Attachment - Perfect for Mixing Compost, Sludge, or Flammables
This excavator attachment is ideal for mixing compost, sludge, or flammables into the soil for fire prevention and other uses. It can also be used to inject cement slurry through the protected spray hose and nozzle, located between the paddles, to mix sand, gravel, or other materials, creating a hard cement surface.
Key Features:
Condition: Little-used unit
Mounting: Comes with 90 mm pins for any 250-350 class excavator. It is also set up to mount on our Helac PT-12 160-degree tilt wrist coupler. See my other ad for this complete coupler, bucket, and blade combo:
Adaptability: Can be bushed down to 80 mm pins for 200-240 class excavators.
Price:
Take this low-hour unit with factory stand for just $20,000.00 (New cost well over $100,000.00 plus 6 months lead time).
Contact:
Frank: 604-476-7777
Videos:
Download the Allu PDF:
https://www.allu.net/?post_type=allu_industry&p=2533
Specifications:
Make: Allu
Model: PM200
Basic Machine Size: 20-30 tons
Transport Dimensions: 101" L x 56" W x 61" H
Operating Weight: 4,200 lbs
Power: 80 KW (108 HP) at 100 litres per minute flow at 2500 PSI
Unit Features:
Designed for durability
Easy mounting
Effective mixing of different materials
Pin Diameter: 90 mm
Distance to Pins (OC): 19"
Distance to Ears (ID): 16"
Fits: Set up for any 250-350 class excavator
Maximum working depth: 78"
Hydraulic: Two-way rotation
About ALLU PM Power Mix:
ALLU PM Power Mix is a hydraulic equipment attachment for excavators, turning them into mobile and efficient mixing plants.
It can handle very hard materials such as clay, peat, silt, sludge, or polluted soil.
Mixing efficiency is enhanced by the optimal horizontal position of rollers and unique design of mixing elements, which move and mix material in three directions simultaneously.
Processes material to a depth of 3 meters, depending on the excavator's equipment and material condition.
Designed for time-consuming tasks with solid steel welded construction and wear-resistant steel parts.
Minimal maintenance required, with easy mounting options.
Additional Features with ALLU Power Mix Feed System:
The ALLU PM power mix is a versatile accessory for excavators for in-situ soil stabilization.
Processes a variety of materials on-site for cost-effective operation.
Horizontal drums allow the ALLU PF pressure feeder to inject the binding agent directly to the middle of the mixing drums, guaranteeing better mixing to the base material.
The PF is a remote-controlled unit that follows behind the lead excavator.
Available in three different model sizes to reach 1.5, 3, and 4.6 meters depth.
For more information, call 800/939-2558 or visit www.allu.net.
