Menu
Quick Eze Links
2020 Rockwheel MXR-D30LH Twin Drum 20-42 Class Excavator Mixer
Posted Date: Oct 21st, 2023 at 02:27 AM
0.0 star
Price: 30000.00 Negotiable
2020 Twin Drum 20-42 Class Excavator Mixer Rockwheel MXR-D30LH with an 80mm pin top plate and 12.75 inches between the ears
Additionally, the 150 horsepower hydraulic head and cutter pick system of the Perfect Stumps grinder allow for the removal of trees, mixing, and grinding of brush into the ground for fire prevention.
THESE RENT FOR:
ROCKWHEEL D30 ROTARY RENTAL RATES Daily $1,300 Weekly $3,900 4 Weeks $11,700
See the Rockwheel Information page - copy and paste this link:
https://rockzoneamericas.com/en/products/categories/soil-mixers
SEE THE COMPLETE ROCKZONE WEBSITE FOR ALL APPLICATIONS THIS UNIT CAN DO - (COPY AND PASTE) :
https://rock.zone/en/
OR SEE ALL VIDEOS OF THESE IN ACTION:
https://www.youtube.com/user/ALPINECUTTERS/videos
Soil remediation tools for treatment of Soil, Sludge, Dredged material, contaminated sites, and oil & gas drilling waste.
Excellent Condition 2019 Unit Ready to Work c/w Pin Grabber Top Plate Mounting System
New Cost $100,000.00 Take It For $30,000.00 BEFORE WE MOVE BACK TO NB
Frank 604-476-7777
MXR-D30LH Specifications:
Input Power hp (kW) 150 (110) Required Flow Rate GPM (l/min) 55-110 (208-412) Max Operating Pressure max. psi (bar) 5800 (400) Drum Speed RPM 75 - 140 Mixing Head Torque (max) ft.lb (Nm) 17,250 (23.4) Weight (without bracket) lbs (kg) 3600 (1635) Intended Carrier Size: 25-42 ton Mixing blades customized for the job. Affects drum dimensions • Suitable for wet or dry mixing • Compatible with pressure feeder systems
•OPTIONS THAT ARE INCLUDED:
Injection Piping And Spraying Piping Extension Brackets Extreme Duty Blade Configuration Quick Hitch Pin Grabber Mounting Bracket
Optional:
• Long housing offers a deeper depth reach and reduced housing debris obstruction • Optional depth limiter & collision preventer
Note: Drums can be quickly changed to many drum configuaration see the Rockwheel Brochure (copy and paste)
The Twin Drum series of mixers from Alpine can be used by carriers of any size. Regardless of the size of your job, we have you covered with everything from tiny minis to 75+ ton excavators. These instruments can be utilized in the most demanding situations thanks to strong, long-lasting gearboxes that were adapted from the mining sector. To mix materials ranging from liquid sludges to firm compact soil, we provide a range of drum configurations. These units have the highest torque available, and we can perfectly match the soil mixing attachment to your application thanks to the different motor options available for each model.
It is possible to outfit any of Alpine's soil mixers with injection piping for wet or dry additives. We can design and construct custom extension brackets if your application calls for a specific depth reach.
Technical details
Each MXR model is equipped with a variety of motor configurations that enable customization for site-specific conditions and compatibility with the carrier excavator's hydraulic output, making it robust enough for even the most demanding applications.
Apart from maximizing the speed, torque, and input power, drums are engineered to achieve maximum blending efficiency and substrate homogenization. High surface area contact between the additives and substrate, as well as simultaneous lateral flow and vertical shearing, are produced by the dual, discontinuous spiral pattern of the mixing blades. There are options for custom drum design and construction.
Intended Carrier Size: 20-42 ton
• Mixing blades customized for job. Affects drum dimensions
