Menu
Quick Eze Links
2020 OKADA TOP150 - 3000 FT-LBS CLASS HYDRAULIC ROCK BREAKER
Posted Date: Oct 19th, 2023 at 11:45 AM
0.0 star
Price: 30000.00
O hours have passed since the rebuild of the OKADA factory shop, the sealing of the low-hour mint condition hammer, and the painting and decaling of the piece by OKADA America.
WE GET GREAT RATES AND FAST SERVICE - OR WILL SHIP ON BUYER'S ACCOUNT
WE WILL DEAL WITH ALL CUSTOMS IF COMING TO CANADA
TAKE THIS UNIT FOR $30,000.00. THIS WILL SHIP DIRECTLY FROM OKADA OREGANS NEW 24,000 SQ FOOT SHOP TO BUYER.
FRANK RAYNER 604-476-7777
The medium class breakers from Okada come in a variety of designs, some of which are ideal for combining concrete and rock breaking with the possibility of faster blow speeds, and others of which are specifically designed to deliver maximum impact energy for the hardest rock applications.
All main breaker components are produced using Okada quality control procedures and precision machining techniques. Complete assembly replacements are not necessary, and the Okada breaker can be inexpensively and labor-savingly rebuilt thanks to the use of high-precision parts.
Heavy gauge high tensile steel plates are used to make breaker brackets, which are intended to protect the breaker body to the fullest extent possible and to dissipate heat while facilitating easier access to the equipment for routine maintenance inspections.
The service life of wear parts is increased by Okada bushing designs, a unique heat treatment procedure, and individually lubricated bushings.
The highlighted model might be accompanied by other models. Options may be displayed for the equipment. Specifications can change at any time without notice.
OKADA WEBSITE FOR THIS HAMMER (copy and paste) : https://okadaamerica.com/en/top150
OKADA PDF BROCHURE FOR THIS HAMMER : https://okadaamerica.com/dl-9780/TOP%20Brochure%207-2021.pdf
Technical Data
IMPACT ENERGY CLASS 3000 ft-lb / 4068 JOULES OPERATING WEIGHT 3000 lbs / 1361 kg OIL FLOW 30-35 gpm / 114-132 lpm FREQUENCY 600-750 bpm L-mode OPERATING PRESSURE 2030-2620 psi / 140-180 bar MECHANICAL ENERGY 42-63 hp / 31-47 kw MECHANICAL ENERGY AVG 52.5 hp / 39 kw UNIT WORKING LENGTH 94 in / 239 cm TOOL DIAMETER 4.8 in / 122 mm TOOL WORKING LENGTH 24 in / 610 mm CARRIER WEIGHT RANGE 28-42 lbs. / 13-19 M ton
2020 OKADA TOP150 - 3000 FT-LBS CLASS HYDRAULIC BREAKER FACTORY RESEAL
LOW HOUR MINT CONDITION HAMMER - O HOUR SINCE RESEALED BY OKADA AMERICA C/W RE-PAINT AND RE-DECAL
WE GET GREAT RATES AND FAST SERVICE - OR WILL SHIP ON BUYERS ACCOUNT
FRANK RAYNER 604-476-7777 https://www.youtube.com/watch?v=_9Aib30B774
