2019 ELECTRIC Toyota 6BWS20 Industrial Walk-Behind Electric Pallet Jack Lift Truck 24V c/w charger
Dec 13th, 2023 at 19:39 Industrial - Machinery Willoughby 112 views Reference: 428Location: Willoughby
Price: $10,000 Negotiable
2019 ELECTRIC TOYOTA 6BWS20 ELECTRIC WALKIE STRADDLE STACKER
PERFECT CONDITION MACHINE FROM HERC RENTALS THAT WAS UNDER
FULL MAINTENANCE PROGRAM LAST SERVICED JULY 13, 2023
NOTE: NO FORKLIFT CERTIFICATION NECESSARY FOR OPERATOR
Make: Toyota
Model: 6BWS20
Serial Number: 6BWS20-10334
Transport Dimensions: 92" L x 53" W x 72" H
Transport Weight: 4,645 lbs
ELECTRIC 3 STAGE MAST MAST LOWERED 71″ MAST RAISED 150″ 4000 LB CAPACITY SIDE-SHIFT CUSHION TIRES WALKIE STACKER
PERFECT FOR TIGHT WAREHOUSES LOADING PALLET RACKING TO 150 INCHES - WORKING IN A MECHANICS SHOP - LOADING AND UNLOADING TRUCKS FROM THE GROUND
COMES WITH ONBOARD HIGH QUALITY DELTA-Q CHARGER 24 VOLT, 50 AMP, CHARGER ONLY DELTA-Q IC SERIES BATTERY CHARGER - BATTERY CONDITIONER 110 VOLT OVER NITE CHARGER WORTH OVER $1200.00
The Delta-Q, 941-0001, IC1200 is a 24V 50A high performance battery charger capable of charging lead acid (wet/flooded, AGM, Gel) and lithium batteries.
Ideal for industrial applications (work platforms, aerial / scissor lifts), floor machines, golf carts, electric vehicles, fork lifts and pallet jacks.
The Delta-Q IC1200 is equipped with an onboard USB port for to retrieve stored cycle data as well as performing software and charge profile updates.
Features
Multi-color LED indicator for AC Source, Battery Status, Charging, Error and Fault
Numeric Display for Charge Profile, Alarm / Fault Codes
Field Programmable with 25 Charge Profiles
Auto-Recharge for Low-Voltage in Maintenance Mode
OEM Customizable
Field Replaceable Cable design
SEE IMAGE #4 FOR THE SAME UNIT 4 SERIAL NUMBERS OFF THIS SAME MACHINE THAT THEY ARE ASKING $15,985.00 USD ($21,500.00 CDN) FOR
WATCH THE VIDEO OF THIS ACTUAL UNIT WORKING
NARROW AISLE FULL FREE LIFT ID 44″ OD 52″ READY TO WORK CONTACT US FOR MORE DETAILS OR
TAKE THIS WELL MAINTAINED LOW HOUR UNIT FOR $10,000.00 CDN
YEAR:2019
MANUFACTURER:Toyota
MODEL #:6BWS20
CAPACITY:4000
FUEL:Electric - 24 VOLT ELECTRIC C/W
SUBCATEGORY:Electric Walkie Straddle Stacker
MAST TYPE:Three Stage
MAST SPEC:150
SERIAL #:6BWS20-10334
SIDE SHIFTER:Yes
CONDITION:Used
JUST LOWERED THE PRICE ON THIS UNIT TO MOVE THIS EQUIPMENT QUICKLY -FRANK 604-476-7777 or TOLL FREE Phone : 1-(833) 693-9323 UNIT LOCATED IN OUR LANGLEY BC YARD - AFTER 53 YEARS IN EXCAVATION - TRUCKING - DEMOLITION WE ARE RELOCATING TO NB AND PRICING ON ALL EQUIPMENT REFLECTS THAT FOR A QUICK SALE
