2019 ELECTRIC TOYOTA 6BWS20 ELECTRIC WALKIE STRADDLE STACKER
Oct 25th, 2023 at 16:56 Industrial - Machinery Langley 232 views Reference: 309Location: Langley
Price: $10,000 Negotiable
A fully maintained machine from Herc Rentals, the 2019 Toyota 6BWS20 electric walkie-stick stacker is in perfect condition.
It was last fully serviced on July 13, 2023.
NOTE: THE OPERATOR DOES NOT NEED A FORKLIFT CERTIFICATION
24V c/w charger for Toyota 6BWS20 Industrial Walk-Behind Electric Pallet Jack Lift Truck
Brand: Toyota
6BWS20-10334 is the serial number for this model.
Measurements for transportation: 92" L x 53" W x 72" H; weight: 4,645 lbs.
3 STAGE ELECTRIC CUSHION TIRES WALKIE STACKER, 71 INCH MASS RAISED TO 150 INCH, SIDE-SHIFT, 4000 LB CAPACITY
IDEAL FOR TIGHT WAREHOUSES - USING A MECHANICS SHOP - LOADING AND UNLOADING TRUCKS FROM THE GROUND - PALLET RACKING TO 150 INCHES
A BATTERY CONDITIONER 110 VOLT OVER NIGHT CHARGERWORTH OVER $100, INCLUDES AN ONBOARD HIGH QUALITY DELTA-Q CHARGER24 VOLT, 50 AMP, CHARGERONLY DELTA-Q IC SERIES BATTERY CHARGER $12,000
A 24V 50A high performance battery charger, the Delta-Q, 941-0001, IC1200, can charge lithium and lead acid (wet/flooded, AGM, and Gel) batteries.
Perfect for floor machines, golf carts, electric vehicles, pallet jacks, work platforms, aerial / scissor lifts, and electric vehicles.
The onboard USB port of the Delta-Q IC1200 allows for software and charge profile updates in addition to retrieving stored cycle data.
Features
Multi-color LED indicator for AC Source, Battery Status, Charging, Error and Fault
Numeric Display for Charge Profile, Alarm / Fault Codes
Field Programmable with 25 Charge Profiles
Auto-Recharge for Low-Voltage in Maintenance Mode
OEM Customizable Field Replaceable Cable design
WATCH THE VIDEO OF THIS UNIT WORKING (COPY AND PASTE OR CLICK) :
https://youtu.be/xMn4Onyg6ks
NARROW AISLE FULL FREE LIFT ID 44″ OD 52″ READY TO WORK CONTACT US FOR MORE DETAILS OR
TAKE THIS WELL MAINTAINED LOW HOUR UNIT FOR $15,000.00 CDN
YEAR:2019
MANUFACTURER:Toyota
MODEL #:6BWS20
CAPACITY:4000
FUEL:Electric - 24 VOLT ELECTRIC C/W
SUBCATEGORY:Electric Walkie Straddle Stacker MAST TYPE:Three Stage
MAST SPEC:150 SERIAL #:6BWS20-10334 SIDE SHIFTER:Yes
CONDITION: LIGHTLY Used
