2019 ELECTRIC TOYOTA 6BWS20 ELECTRIC WALKIE STRADDLE STACKER
Oct 19th, 2023 at 20:14 Industrial - Machinery Cambridge-Narrows 163 views Reference: 270Location: Cambridge-Narrows
Price: $10,000 Negotiable
PERFECT CONDITION MACHINE FROM HERC RENTALS THAT WAS UNDER
FULL MAINTENANCE PROGRAM LAST SERVICED JULY 13, 2023 NEXT SERVICE DUE OCTOBER 13, 2023
NOTE: NO FORKLIFT CERTIFICATION NECESSARY FOR OPERATOR
Toyota 6BWS20 Industrial Walk-Behind Electric Pallet Jack Lift Truck 24V c/w charger
Make: Toyota
Model: 6BWS20
Serial Number: 6BWS20-10334
Transport Dimensions: 92" L x 53" W x 72" H
Transport Weight: 4,645 lbs
ELECTRIC 3 STAGE MAST MAST LOWERED 71″ MAST RAISED 150″ 4000 LB CAPACITY SIDE-SHIFT CUSHION TIRES WALKIE STACKER
PERFECT FOR TIGHT WAREHOUSES LOADING PALLET RACKING TO 150 INCHES - WORKING IN A MECHANICS SHOP - LOADING AND UNLOADING TRUCKS FROM THE GROUND
COMES WITH ONBOARD HIGH QUALITY DELTA-Q CHARGER 24 VOLT, 50 AMP, CHARGER ONLY DELTA-Q IC SERIES BATTERY CHARGER - BATTERY CONDITIONER 110 VOLT OVER NITE CHARGER WORTH OVER $1200.00
The Delta-Q, 941-0001, IC1200 is a 24V 50A high performance battery charger capable of charging lead acid (wet/flooded, AGM, Gel) and lithium batteries.
Ideal for industrial applications (work platforms, aerial / scissor lifts), floor machines, golf carts, electric vehicles, fork lifts and pallet jacks.
The Delta-Q IC1200 is equipped with an onboard USB port for to retrieve stored cycle data as well as performing software and charge profile updates.
Features
Multi-color LED indicator for AC Source, Battery Status, Charging, Error and Fault
Numeric Display for Charge Profile, Alarm / Fault Codes
Field Programmable with 25 Charge Profiles
Auto-Recharge for Low-Voltage in Maintenance Mode
OEM Customizable
Field Replaceable Cable design
SEE IMAGE #4 FOR THE SAME UNIT 4 SERIAL NUMBERS OFF THIS SAME MACHINE THAT THEY ARE ASKING $15,985.00 USD ($21,500.00 CDN) FOR
WATCH THE VIDEO OF THIS UNIT WORKING (COPY AND PASTE OR CLICK LINK) :
https://youtu.be/xMn4Onyg6ks
NARROW AISLE FULL FREE LIFT ID 44″ OD 52″ READY TO WORK CONTACT US FOR MORE DETAILS OR
TAKE THIS WELL MAINTAINED LOW HOUR UNIT FOR $10,000.00 CDN
YEAR:2019
MANUFACTURER: Toyota
MODEL #:6BWS20
CAPACITY:4000
FUEL:Electric - 24 VOLT ELECTRIC C/W
SUBCATEGORY:Electric Walkie Straddle Stacker
MAST TYPE: Three Stage
MAST SPEC:150
SERIAL #:6BWS20-10334
SIDE SHIFTER: Yes
CONDITION: Used
JUST LOWERED THE PRICE ON THIS UNIT TO MOVE THIS EQUIPMENT QUICKLY -FRANK 604-476-7777 or TOLL FREE Phone : 1-(833) 693-9323 UNIT LOCATED IN OUR LANGLEY BC YARD - AFTER 53 YEARS IN EXCAVATION - TRUCKING - DEMOLITION WE ARE RELOCATING TO NB AND PRICING ON ALL EQUIPMENT REFLECTS THAT FOR A QUICK SALE
