2012 International 7400 – Altec Crane with Digger (Tandem Axle)
Posted Date: Aug 5th, 2025 at 04:41 AM
0.0 star 161 views
Price: $63830.00
Heavy-Duty | Pole Setting | Work-Ready Unit
🔧 Truck Specifications:
  • Make/Model: International 7400
  • Year: 2012
  • Engine: [Confirm – likely International MaxxForce 9/10 or Cummins ISL] high-torque diesel engine
  • Transmission: [Confirm – Eaton Fuller manual or Allison automatic]
  • Drive: Tandem axle heavy-duty vocational chassis – excellent for crane and auger operations
  • GVWR: High-capacity vocational rating for crane and digger use
  • Cab: Day cab with premium driver’s seat, ergonomic controls, A/C, and comfort features
🔧 Crane & Digger Specifications:
  • Brand/Model: Altec [Insert exact model if known]
  • Type: Hydraulic crane with auger/digger attachment
  • Max Lifting Capacity: [Confirm – typically 15–25 ton range depending on model]
  • Boom Reach: [Confirm exact horizontal/vertical reach – approx. 40–60+ ft]
  • Digger/Auger: Hydraulic auger for drilling and pole setting operations
  • Controls: Hydraulic controls and/or remote operation for precision handling
  • Condition: Fully operational, well-maintained, work-ready
  • Rugged International 7400 tandem axle chassis for maximum stability and durability
  • Altec crane with integrated digger – perfect for utility, telecom, and construction work
  • Outriggers for excellent stability during lifting and drilling
  • Versatile setup – dig, lift, and place poles or heavy materials with one unit
  • Spacious, comfortable cab with driver-focused controls
  • Maintained and ready for immediate service
  • Utility pole setting and replacement
  • Electrical and telecom construction
  • Oilfield and industrial service work
  • General construction lifting and drilling applications
