******* SOLD ******** SIMEX TF2000 DUAL DRUM PLANETARY DRIVE ROTARY EXCAVATOR GRINDER
May 16th, 2023 at 19:08 Automobiles Langley 529 views Reference: 185Location: Langley
Price: $100,000 Negotiable
Looking To Trade This Simex High End $125,000.00 Grinder For A High End Hot Rod - Muscle Car or Classic Convertible
Please Call or Text or Message me with what you have to trade:
$125,000.00 NEW COST GRINDER PERFECT FOR 30 TON - 50 TON EXCAVATORS
NOTE: THIS IS THE ONLY USED SIMEX TF2000 FOR SALE USED EXCEPT SHEARFORCE WHO WANT $97,500.00 FOR THEIRS SEE IMAGE # 4.
BARELY USED EXCELLENT WORKING UNIT C/W HOSES AND PINS - ORIGINAL FACTORY PAINT AND 40 NEW QUALITY CARBIDE PICKS / TEETH C/W RETAINERS - 20 EXISTING PICKS ARE GOOD - THIS GIVES YOU ALL GOOD OR NEW PICKS
CURRENTLY SET UP FOR OUR EC480DL VOLVO OR CAT 345-352 WITH PIN GRABBERS
WITH 100 MM MAIN FRONT PIN AND 90 MM REAR PIN BUT WILL FIT ANY 350-450 CLASS PIN GRABBER COUPLER
NOTE: THIS HAS 110 MM FRONT PIN BORES WITH 18.5 INCHES BETWEEN EARS WHICH WE TURNED THE PIN TO 90 MM TO PIT A CAT 330 - 336 EXCAVATOR
AND 100 MM REAR PIN BORES WITH 17.25 INCHES BETWEEN THE EARS
EASILY BUSHED FOR ANY 90 - 100 - 110 MM PINS
TAKE IT FOR $45,000.00 or TRADE FOR YOUR HOT ROD - MUSCLE CAR - OR CLASSIC CONVERTIBLE
WILL SHIP QUICKLY WE GET GREAT RATES AND SERVICE
Recommended excavator weight (1) 28-45 ton 61700-99000 lbs
Weight without bracket 2410 kg 5300 lbs
Drum width (standard) 950 mm 38 inch
Simex TF cutter heads are ideal for trenching, profiling rock and cement walls, tunneling, quarrying, demolition, dredging, finishing operations, and underwater works.
They are highly effective where conventional excavation systems are too weak and percussion systems have little effect.
Their quiet operation allows them to be put to work near sensitive areas (residential zones, hospitals, schools, bridges, and infrastructure).
Especially recommended for finishing operations, where high precision, minimum disturbance, and the optimum aesthetic result are required.
Features
* Precise cut
* Low vibrations
* High performance
* Low noise level
* Deep and narrow trenches
* Underwater works
* Maintenance-free
* Milled material reused on site
