(SOLD) MIDI TO 170 CLASS EXCAVATOR BRUSH CUTTER C/W FLOW VALVES-PIPING
Posted Date: May 7th, 2023 at 12:04 PM
Price: 7500.00 Negotiable
BRUSH CUTTER SET UP FOR 65 MM PINS WITH 10 INCHES BETWEEN THE EARS OR REMOVE THAT
TOP PLATE FOR 70 MM PINS WITH 11 INCHES BETWEEN THE EARS
COMES C/W 12 OR 24 VOLT ELECTRIC FLOW CONTROL $3000.00 QUALITY VALVE
ALSO BOTH BOOM AND STICK HARD LINES AND SOFT LINES WORTH OVER $5000.00
CUTTER HAS FLIP-UP FRONT AND BOTH SIDES SO YOU CAN OPEN THE SIDE YOU ARE CUTTING DIRECTION TO TAKE DOWN TREE UP TO 6 INCHES
ALSO HAS A REAR BRACKET SO YOU CAN GRAB AND MOVE TREES ROCKS ETC WITH YOUR THUMB
COMMERCIAL SHEARING DRIVE MOTOR WITH CASE DRAIN PLUMBED INTO RETURN LINE SO YOU ONLY NEED POWER IN AND RETURN LINE
FLIP OVER 2 CUTTING EDGES BLADES THAT YOU CAN TURN OVER TO KEEP SHARP EDGE CUTTING.
TAKE THIS UNIT COMPLETE FOR $7000.00
JUST LOWERED THE PRICE TO TO MOVE THIS QUICKLY
SEE MY OTHER EXCAVATING AND DEMOLITION EQUIPMENT FOR SALE AS RETIRING BACK TO OUR NEW HOME IN NB DUE TO HEALTH ISSUES FROM THE FOREST FIRE SMOKE PARTICULATES AND EXTREME TRAFFIC AND ITS SMOG IN THE FRASER VALLEY AND CLEARING OUT MY YARD TOTALLY
