******** SOLD ******* 2023 Mercury 20 HP 4 STROKE EFI 20ELH ELECTRIC START
Nov 2nd, 2023 at 02:39 Boats / Watercraft Cambridge 377 views Reference: 362Location: Cambridge
Price: $3,000 Negotiable
2023 Mercury 20 HP EFI EFI 20ELH Short Shaft Outboard Motor 4 Hours TT
THIS WAS BOUGHT WHEN WE INFACT NEEDED A LONG SHAFT - BUT DEALER WOULD NOT TAKE BACK AS WE PUT 4 HOURS ON IT??
WE PAID OVER $4000.00 PLUS TAXES
TAKE THIS NEW MOTOR FOR $3000.00 AND I WILL THROW IN THE MOTOR STAND WE BUILT
LOCATED OUR WATERFRONT HOME CAMBRIDGE NARROW NB
THIS IS A PRIVATE SALE - SO NO TAXES REQUIRED
HAVE ALL FACTORY MANUALS
PRODUCT DESCRIPTION
The Mercury 20 hp EFI outboard motor model 20ELH is an electric start outboard with a 15 inch short shaft with electric start, and multi function tiller handle.
This low end torque engine has the power and prop needed to quickly plane your boat.
Known for reliability, and fast acceleration, the 20 HP EFI portable outboard by Mercury is an affordable option especially considering the long list of standard features and the Mercury 3-year warranty. Your online outboard shopping ends here!
20hp HORSEPOWER
11.0 lb WEIGHT
Shaft Length: 15" (Long)
Starting: Electric
SKU: 20ELH-24EFI
PRODUCT DESCRIPTION
Fast throttle response and fast acceleration are features designed into the 20 HP EFI Mercury Outboard.
With powerful low end torque and a large displacement your boat planes faster and you get to your destination across the water faster thanks to Mercury engineering.
At 111 lbs. the Mercury 20 HP EFI model 20MH is your affordable choice in the 20 HP line up with a ELECTRIC start and the 15 inch short shaft.
The 20MH also includes manual tilt, a heavy duty transom bracket, vibration absorbing mounts and Mercury's multi function tiller.
- FEATURES
- SHAFT LENGTH GUIDELINES https://onlineoutboards.com/collections/mercury-20-hp-outboards/products/2024-mercury-20-hp-efi-20mh-outboard-motor
- DOWN LOAD PDF FILE : https://samerwebapp01apncus01.azureedge.net/mmgw-env-b/filer_public/31/31/313104cb-9996-494a-b850-1369d83a5a49/8m0189527_fourstroke_brochure_25_20hp_.pdf
- Large Displacement Powerhead (351cc)
- Thru-Cowl Backup Manual Start
- Digital CD Ignition with Spark Advance
- Tuned Intake for Quick Acceleration
- High Grade Marine Alloy Construction
- Stainless Steel Water Pump Housing
- Zinc Coated Water Passages
- Rated for Saltwater Use
- Sacrificial Zinc Anodes and Trim Tab
- Tiller Integrated F-N-R Gear Shifting
- Adjustable Steering Tension Control
- Twist-Grip Throttle with Tension Control
- Thermostat Controlled Water Cooling
- Heavy Duty Transom Mounting Bracket
- Quiet Through-Propeller-Hub Exhaust
- "Wishbone" Mount for Reduced Vibration
- 3.2 Gallon Fuel Tank and Fuel Line
- Easy Maintenance Canister Oil Filter
- Start-In-Gear Protection
- Low Oil Pressure Warning Indicator
- ESG Over-Rev Protection
- Safety Lanyard Stop Switch
- Owner's Manual
- Mercury Marine 3-Year Warranty
MODEL | 1A20201LK |
MODEL YEAR | 2023 |
SKU | 20MH-24EFI |
WEIGHT | 111.0 lb |
MANUFACTURER | Mercury |
COUNTRY OF MANUFACTURE | Japan |
HORSEPOWER | 20hp |
SHAFT LENGTH | 15" (Short) |
STEERING | Tiller |
STARTING | ELECTRIC |
TRIM & TILT | Manual |
FUEL DELIVERY | EFI |
FUEL TANK | External |
CYLINDER(S) | 2 |
DISPLACEMENT | 333 cc (20.3 cubic inches) |
BORE AND STROKE | 61 mm x 57 mm (2.402 in. x 2.244 in.) |
FULL THROTTLE RPM RANGE | 5400-6100 |
IGNITION SYSTEM | CDI w/electronic spark advance |
INDUCTION SCAVENGING | SOHC |
VALVES PER CYLINDER | 2 |
FUEL TYPE | 87 octane/up to 10% ethanol |
FUEL TANK / FUEL LINE | 3.2 Gallon/12 Liter |
OIL TYPE | Mercury 4-Stroke Outboard Oil |
OIL CAPACITY | 1 Quart (1000 ml) |
LUBRICATION | Trochoid Pump |
ALTERNATOR | Optional 12 amp / 138 watt (Electric) |
COOLING SYSTEM | Water-cooled with thermostat |
SALTWATER RATED | Yes |
GEAR RATIO | 2.15 |
GEAR SHIFT | Forward-Neutral-Reverse |
PROPELLER | 9.2" Diameter X 9.1" Pitch 3-Blade Aluminum |
