***** SOLD ******* J40-XN HYSTER 36 VOLT 4000 LB ELECTRIC FORKLIFT 2500 HRs LOADED OPTIONS
Apr 8th, 2024 at 17:50 Industrial - Machinery Willoughby 119 views Reference: 589Location: Willoughby
Price: $22,000 Negotiable
REPLACEMENT COST WITH ALL OPTIONS AND RARE SINGLE PHASE 140 AMP 220 VOLT AUTOMATIC BATTERY CONDITIONING CHARGER IS OVER $60,000.00 + PLUS 4 MONTH WAIT TIME AS CUSTOM FACTORY ORDER REQUIRED
THIS IS A LOW 2520-HOUR POWER-ON TOTAL TIME - 2420 TOTAL WORKING HOURS MINT CONDITION 36 VOLT FORKLIFT C/W FINGERTIP CONTROLS FOR RAISE - LOWER FORKS - FORWARD - BACK TILT BOOM - FORWARD AND REVERSE - SIDE SHIFT - FORK POSTIONERS - HORN
FROM THE SEAT RIGHT HAND ARM REST.
THIS IS A FULL-LOAD FORKLIFT WITH ALL FACTORY OPTIONS WE PURCHASED FROM BOEING AIRCRAFT OUT OF WA STATE FOR USE IN OUR PARTS SHOP AS IT TURNS IN NARROW AISLES BETWEEN PALLET RACKING BUT AS WE ARE LEAVING BC - WE NO LONGER NEED IT.
READY TO WORK - TAKE IT COMPLETE WITH AN AS NEW 220-240 VOLT RARE 1 PHASE AUTOMATIC AND BATTERY CONDITIONING CHARGER FOR $25,000.00 - THIS PLUGS INTO ANY 220 VOLT SINGLE PHASE SERVICE WITH A TWIST LOCK PLUG
WE DO HAVE A NEW HYSTER FACTORY BOTTOM SEAT CUSHION IN THE BOX THAT GOES WITH THE UNIT.
THIS FORKLIFT FUNCTIONS AND TURNS IN ITS OWN LENGTH WITH A 0 TURN RADIUS JUST LIKE THE ONE IN THE VIDEO
Specifications:
Type: 4 Wheel Electric - 0 Turn Radius - Finger Tip Controls For All Functions - $5000.00 option
Make: Hyster
Model: J40XN
Capacity: 4000lbs @ 24” Load Center
Mast: 3-Stage Full free lift (187” Max Lift Height)
Attachment: Side Shifter - Hydraulic Fork Positioner - $5000.00 Option
Forks: 42”
Fuel: Electric - 36 Volt - BATTERY TAKES 100% CHARGE GOOD FOR 4 OR 5 HOURS OF WORKING TIME
Charger: Included Fully Automatic As New 220-240 Volt 1 Phase c/w Battery Conditioning Cycle - $2500.00 option
Tires: *AS NEW* Traction Cushioning - see images
REPLACEMENT COST WITH ALL OPTIONS AND CHARGER IS OVER $60,000.00 + PLUS 4 MONTH WAIT TIME AS CUSTOM FACTORY ORDER REQUIRED
SEE ALL THE LIFT TRUCK OFFERS WITH A PDF FILE SHOWING THE FOLLOWING: (CLICK OR COPY AND PASTE)
The J30-40XNT/XN series of electric lift trucks from Hyster Company offers numerous advantages in performance and ergonomics that make them some of the most operator-friendly AC-powered lift trucks on the market.
The innovative design of our three-wheel and four-wheel electric trucks provides you with a variety of solutions depending on your needs.
The compact design and tight turning radius of the three-wheel truck gives you incredible maneuverability in the tightest locations.
The four-wheel truck, with its Zero Turning Radius (ZTR) axle, offers maneuverability similar to a three-wheel truck, with greater comfort when traveling over longer distances.
Superior operator comfort and customizable performance, that matches operator skill with individual performance needs, enable the J30-40XNT/XN to give maximum productivity throughout the entire shift.
The J30-40XNT/XN delivers more bottom-line savings by increasing productivity and uptime through the use of AC motors and transistor controller technology for all traction and hydraulic systems, which reduce the frequency and cost of maintenance.
Using cutting-edge components and intelligent system design, the J30-40XNT/XN operates longer, with minimal downtime, and is assembled on a state-of-the-art assembly line utilizing the latest in manufacturing processes and techniques.
EXCLUSIVE VISTA™ MAST High-strength hot-rolled steel mast channels and flush-faced design improve capacity retention at high lifts.
Compact cast steel cross members optimize visibility and rigidity. Six canted 3-inch full-face load rollers roll on the web and the flange simultaneously, eliminating the need for side thrust rollers or wear plugs.
TILT STEER COLUMN The infinitely adjustable tilt steer column with optional telescopic column and tilt memory accommodates all operators easily.
Assisted by a gas spring and an easy-to-reach lever, obtaining your preferred position is simple.
REMOVABLE FLOOR PLATE Two-piece steel floor plates and side plates are easily removed to provide instant service access.
A thick molded rubber floor mat seals the floor area to reduce noise and vibration for a more comfortable ride.
PACESETTER VSM The computer “brain” of these lift trucks manages all vehicle systems to optimize performance, significantly increases overall reliability and enhances diagnostic capability to give maximum uptime.
DRIVE AXLE The sealed design of the drive axle enhances dependability and reliability for longer service life.
Hyster oil-cooled wet disc brakes provide smooth stopping with reduced pedal effort as well as long brake life.
SEALED TRANSMISSION Transmission is lubricated for life so there is no need to change the transmission oil.
AC MOTORS The brushless AC traction and hydraulic motors, powered by transistor controls, are durable enough to handle your toughest duty cycle, with reduced maintenance costs and enhanced productivity.
OVERHEAD GUARD The unique grid-style pattern improves visibility while protecting operators and strengthening the truck’s structure.
The front, curved OHG leg design affords greater shoulder clearance for easier operator entry and exit. LED LIGHTS Bright and long-lasting, the optional LED front and rear working lights and brake/tail / back-up lights rarely need replacing.
The plastic lens meets the FDA requirement for use in food applications. A B C D E F G H G
MULTIFUNCTION DISPLAY The location of the multifunction display provides maximum forward visibility and ease of operation.
The display does not obstruct the forward view and is within easy reach of the operator, supervisor or service technician for quick access to truck functions, diagnostics, and troubleshooting.
FATIGUE-REDUCING OPERATOR COMPARTMENT An Ergonomically designed operator compartment helps enhance overall productivity.
Features include: increased foot space and optimized step height for easy entry and exit; fully adjustable, full suspension seat (optional) with low whole body vibration levels; infinitely adjustable steering column with optional memory tilt and telescopic steering wheel and low effort e-hydraulic controls.
The standard non-suspension seat and optional suspension and swivel seats are all easily adjusted to provide a more customized, comfortable ride.
REAR DRIVE HANDLE The Optional handle provides an excellent hand hold for reverse driving while giving ready access to the auxiliary horn button for use when approaching cross-aisles and pedestrian traffic areas.
FOUR-WHEEL DESIGN The J30-40XNT/XN series features a Zero Turn Radius (ZTR) steer axle which provides advanced turning capability and superb maneuverability during operation.
The Hyster Stability System reduces truck lean in turns, allowing superior travel over uneven surfaces.
The stability system requires no maintenance and provides a tighter turning radius for unparalleled maneuverability that makes stacking in limited space and congested loading bays easier than ever.
The dual steer wheels provide a smoother, more stable ride.
The rack-and-pinion hydraulic actuator is sealed from contaminants and moisture for reliable, maintenance-free operation.
