VOLVO EC250EL S LINKS - H LINK C/W STICK END WITH PERFECT BUSHINGS - BUCKET LINKAGE - $1,500 (LANGLEY BC)
Posted Date: Apr 16th, 2026 at 10:19 PM
Price: $1500.00
Complete OEM stick end assembly package removed from a Volvo EC250EL as part of a professional forestry conversion to a log loader configuration.
This is not a failure or damage removal — the machine was converted to a fixed boom / grapple setup, which required removal of the stick end and bucket linkage components (a common practice in forestry and material handling applications).
All components were fully functional at time of removal and have been kept together as a matched set.
What’s Included
Stick end section (dipper end / bucket connection point)
Complete S-link / H-link assembly
Bushings, and shim packs
Associated hardware (as removed)
✔ Sold as a complete package – ready to reinstall or use for rebuild/spares
Condition
Removed in working condition
No known cracks or structural issues
Normal wear consistent with use
Ideal for:
Rebuild projects
Damaged machine repair
Fleet spare parts
Why It Was Removed
The base machine was converted into a log loader / material handler, which required:
Removal of the articulated stick end
Installation of a fixed boom extension + hydraulic grapple
Optimization for log handling, sorting, and loading
Picture of similar machine at end of photos - show why this was removed
This type of conversion is standard in forestry operations and does not reflect any issue with the removed components.
Applications / Compatibility
Direct replacement for Volvo EC250EL
May fit or be adaptable to similar 25–30 ton excavators (buyer to verify)
Location & Shipping
Located at Nahanni Truck and Trailer 20141 Logan Ave, Langley, BC V3A 4L5, they will load
Contact Frank 604-476-7777
Serious inquiries only.
“Removed for conversion — not because of failure. Hard-to-find complete OEM linkage package.”
| Construction – Brand / Manufacturer | Volvo |
| Construction – Model / Part Number | EC250EL S LINKS C/W STICK END |
| Construction – Condition | New |
| Construction – Location | Langley BC |
| Construction – Part – Compatibility | EC250EL S LINKS C/W STICK END |
| Construction – Part – Part Type | EC250EL S LINKS C/W STICK END |
| Construction – Part – OEM / Aftermarket | OEM |
| Construction – Part – New or Used | New |
