ULC Listed Flammable Storage Cabinets
Posted Date: Apr 7th, 2026 at 10:34 PM
0.0 star 178 views
Price: $3595.00
Enhance workplace safety with our ULC Certified Flammable Storage Cabinets, specifically designed for the secure storage of flammable liquids and combustible substances. These ULC Approved safety cabinets feature 2 inches of fireproof insulation between double-walled, 18-gauge steel construction, offering superior protection against external heat sources.
Rigorously tested and meeting ULC Standards, these cabinets comply with the stringent National Fire Code of Canada 1980 for flammable and combustible liquids. Ideal for hazardous material storage close to your work area, they eliminate the need for frequent trips to remote storage rooms, enhancing both safety and convenience.
Key features include:
  • Double-Wall Construction: 2 inches of fireproof material between inner and outer walls for enhanced insulation.
  • Manual Door Sill: Raised 2 inches above the cabinet bottom, forming a liquid-tight well.
  • Three-Point Lock: Ensures maximum security and durability.
  • Adjustable Leveling Feet: For stability on uneven surfaces.
  • Threaded Vents with Fire Baffles: Two 2-inch vents for proper ventilation.
  • Highly Visible Safety Yellow Enamel: With red bilingual warning, “FLAMMABLE-KEEP FIRE AWAY.”
The adjustable satin-coat galvanized shelves are perfect for accommodating various sizes of Type I and Type II Safety Cans, making these fireproof cabinets ideal for safe and efficient flammable liquid storage. Trust our ULC Listed Cabinets for robust protection and easy access to essential chemicals in your workplace, offering top-tier safety storage solutions.
Industrial Service Type Other
Industrial Compliance or Certifications:
Other Certification
Industrial Industry Focus Commercial
Industrial Response Time 24–48 Hours
