Tysea Mfg’s 60 Inch Mat / Demolition Grapple for 200-350 Excavator new unit ready to work
Posted Date: Dec 17th, 2025 at 10:14 AM
Price: $35000.00
NEW - NEVER INSTALLED
Tysea Mfg’s 60” Mat / Demolition Grapple
For 200-350 Class Excavators
Heavy-duty & versatile – Perfect for:
Loading, unloading, and placing mats
Demolition dismantling
Loading grinders
Piling brush
Loading trucks and trailers
Why Choose Tysea’s Mat / Demolition Grapple?
✅ Newly designed for efficiency & versatility
✅ Helps protect the environment by handling wood/poly mats
✅ Built tough for extreme worksite conditions
✅ Save time & labor costs with easy handling
Amazing Deal!
Brand New Cost: $80,000 + 5-7 weeks build time
Your Price: $45,000 LOWERED TO $40,000.00 AND WE PAY THE TRUCKING (includes pins for 200-350 class machines)
Available now in Cambridge Narrows, NB – Get it on your machine next week!
FAST & AFFORDABLE SHIPPING AVAILABLE!
☎️ Contact Frank: 604-476-7777
Mat Grapple Features:
Wired control setup using Dan Foss Valve System (requires only one hydraulic valve pressure & return)
Requires two joystick controls with proportional controls
360° rotation for full maneuverability
Heavy-duty rotate bearing for durability
Valve in Head for smoother operation
Replaceable bolt-on cutting edges on both arms
Vis 40 Eaton hydraulic motor rotate
Fully customizable to your specs and more!
⚙️ Ease of Installation:
Pre-wired & plumbed – Simply plug in and start working!
See it in action on YouTube: Watch the demo video
Serving the Following Industries:
✔️ Matting
✔️ Forestry
✔️ Logging
✔️ Mining
✔️ Oil Field
✔️ And many more!
100% Canadian-Owned & Operated – Trusted Worldwide!
Tysea Mfg Inc. – "Don’t Get Stung by the Competition!"
✅ Best Grapple for Ground Mats: Blades on Both Sides (Dual Blade Grapple)
If your primary job is handling ground mats—whether crane mats, swamp mats, or timber mats—there is no comparison:
A grapple with blades on both sides is far superior to any tine/blade hybrid design.
Why Dual Blade Grapples Are Far Superior:
✔ Maximum Grip and Control
Dual blades provide a full-surface clamping force, ideal for lifting, aligning, and stacking heavy mats with absolute precision.
✔ Even, Flat Pressure
Ground mats are rigid and often 4–8” thick—uneven pressure from a hybrid grapple can damage the mat or cause slippage. Blades distribute force evenly for a secure hold.
✔ Safer Handling
When placing mats in tight formations or near live equipment, precision matters. Dual blades allow stable, controlled movements—no shifting, no twisting.
✔ Prevents Damage
Unlike tines that can gouge or split timber, blades apply smooth, flat pressure, protecting your investment in expensive hardwood mats.
✔ Built for Mats – Not Debris
Tine + blade grapples are for brush, stumps, and loose material—not engineered for handling long, heavy, valuable mats.
Why Tine + Blade Grapples Fall Short:
❌ Uneven Clamping – Pressure is concentrated on one side, increasing the risk of cracking or unbalanced loads.
❌ Poor for Flat, Rigid Materials – They simply weren’t designed for the weight or geometry of ground mats.
❌ More Movement = Less Precision – Makes tight placement and stacking much harder and slower.
Recommended Setup for Mat Handling:
Dual blade grapple with hardened, replaceable edges
Minimum 4-point contact area for max stability
Optional rubber pads to reduce wear on mat surfaces
✅ Final Verdict:
For any professional moving or placing ground mats—a dual blade grapple is not just better, it's the only real choice.
☎️ Call Frank Today: 604-476-7777 – Act Fast, Limited Stock!
| Construction – Year of Manufacture | 2021 |
| Construction – Condition | New |
| Construction – Location | Cambridge Narrows NB |
| Construction – Fuel / Power Type | Diesel |
| Construction – Attachment – Compatible Machine Type | Excavator |
| Construction – Attachment – Pin Size | 90 mm |
| Construction – Attachment – Weight | 4500 |
| Construction – Attachment – Width | 60 |
| Construction – Attachment – Capacity | 12000 |
I’m very satisfied with the TYSEA MFGS 60-inch Mat Demolition Grapple for 200-350 Excavator — it’s rugged, reliable, and ready to work right away. The grapple handles heavy materials with ease, fits perfectly, and boosts productivity on demolition jobs. Excellent quality and performance. Highly recommend this unit!
