STANLEY 200-380 CLASS HS2000 20000 FT LB PLATE COMPACTOR/DRIVER
Posted Date: May 5th, 2026 at 11:23 AM
Price: $6000.00
THE NEW HOSES, NEW 80 MM PINS, AND THE INTERNAL FLOW CONTROL VALVE ARE INC
BUSHED DOWN TO 80 MM PINSCURRENTLY; REMOVE BUSHINGs TO RETURN TO 90 MM PINS
DISTANCES THE EARS BY 15 INCHES
It is fully operational and in excellent LOW-HOUR condition.
With a 32-by-42-inch baseplate, 20,000 pounds of centrifugal force, 1800–2250 psi hydraulic pressure, and 2100 vibrations per minute.
Qualities:
Compactors mounted on Stanley frames offer a significant amount of centrifugal force, varying from 3,400 to 20,000 pounds.
These machines have a higher compaction force than a walk-behind plate compactor, which makes them easier to use and more comfortable for operators because they don't require someone to work in the trench.
An improved valve block cover offers more defense against unintentional harm.
To reduce movement and interference while on the job site, hydraulic hoses are carefully routed close to the frame and covered with a nylon sleeve cover.
Flat-top models make your connection at the carrier easier by being compatible with a wide range of mounting configurations.
Four robust, industrial-grade shock mounts evenly distribute vibration throughout each compactor. This provides steady force to raise the operator's productivity and caliber of work.
Added materials:
Any 300 class excavator can use the pin grabber top mounting system by removing the boring bosses and returning to 90 mm pins.
BUSH BOSSED DOWN THE PIN BORES FOR ANY 200-240 CLASS EXCAVATOR
To run, this plate compactor needs between 1800 and 2250 psi and 42 GPM of flow. The 32 by 42-inch base plate.
This compactor is currently configured to operate on an excavator from the John Deere/Hitachi 200 TO 380 series. PIN GRABBER COUPLER INCLUDED
ASSEMBLEMENT FOR OUR KOMATSU PC360-LC-10, AVAILABLE FOR SALE AS WELL - CHECK OUT MY OTHER ADS
More than $22,000.00 for new
BUY IT FOR 6,000.00 DOLLAR
Located in Cambridge, New Brunswick, in our yard, WE ACHIEVE FAST SHIPPING AT CHEAP RATES
604-476-7777 Frank
For additional plate compactors, such as the FELCO BUCKET COMPACTORS, view my other advertisements.
