Simex TF 1100 DUAL DRUM CUTTER HEAD 240 – 450 Class Excavators - MINING - ROCK SCALING - CEMENT DEMOLTITION
Posted Date: Dec 18th, 2025 at 12:50 PM
Price: $50000.00
✅ Low Hour Demo Model – 35" Excavator Rotary Cutter Head For 36 Inch Trenching and Concrete Resurfacing and Demolition of Wall and Slabs
* Mount Specs:
o 90 mm diameter pins
o 485 mm center-to-center (pin boss)
o 360 mm inside-to-inside pin boss spacing
ORIGINAL PAINT - DECALS AND CUTTING PICKS (TEETH) - HOSES ARE LIKE NEW - READY TO WORK
Key Features:
* Designed for trenching, profiling, cutting rock and cement walls, tunneling, quarrying, demolition, dredging, and even underwater applications
* Especially effective where conventional excavation methods fail and percussion tools are ineffective
* Ideal for carrier weight of 28 to 45 tons (excavators in the 240–450 class)
* Quiet operation makes it suitable for sensitive areas such as:
o Residential zones
o Schools
o Hospitals
o Bridges and critical infrastructure
⚙️ Performance Specs:
* Oil Flow Range: 45–70 GALLONS per minute - MINIMAL 122 HORSE POWER
* Max Operating Pressure: 5800 PSI
* Cutting Speed: 2.2 – 3.5 meters per minute
* Cutting Width: 35 inches – perfect for deep, narrow trenching
Operator Benefits:
* Highly balanced and controllable, making it easier to handle
* Allows for efficient corner cutting and precision work
* Recommended for finishing operations with:
o High precision
o Minimal disturbance
o Superior aesthetic results
PRODUCES EXCAVATED FINISHED 1 1/2 TO 4 INCH MATERIAL PERFECT FOR ROAD BASE OR BACK FILLING
As New Cost c/w 300-350 class pin on / pin grabber wounting plate and hoses: $125,000.00 USD
(Approx. $170,000.00 CAD) – Great value for a low-hour demo unit!
️ See It in Action:
Watch on YouTube: https://youtu.be/BHGg1d8aLYY?si=09FO62UqLZm5Ughy
1921 Lakeview Rd, Cambridge Narrows, New Brunswick E4C 1N
Contact Frank: 604-476-7777
Super Condition. Simex TF 1100 DUAL DRUM CUTTER HEAD 240 – 450 Class Excavators - MINING - ROCK SCALING - CEMENT DEMOLTITION
