ROCKWHEEL 95 HYD HP HYDRAULIC EXCAVATOR TWIN DRUM STUMP GRINDER 180 - 350 CLASS EXCAVATOR SOIL MIXER
Posted Date: Apr 16th, 2026 at 09:12 AM
Price: $15000.00
180 - 350 CLASS EXCAVATOR HYDRAULIC STUMP GRINDER - CUTS TREES DOWN AT THE ROOT LEVEL AND GRINDS ROOTS AND BRANCHES INTO THE SURROUNDING SOIL FOR FIRE PREVENTION
STUMP GRINDER - SOIL MIXER - CAN GRIND TOUGH SHALE - LIMESTONE - HARDPAN AND MORE
THIS IS A LITTLE USED EXCELLENT CONDITION STUMP GRINDER WITH LONG LASTING CARBIDE STUMP GRINDING BITS
THAT CAN ALSO TAKE DOWN AND FELL EVEN LARGER TREES AT THE ROOTS AND GRIND BRANCHES OR BRUSH AND MIX INTO THE SURROUNDING SOIL FOR FIRE PREVENTION
FROM THE ROCKWHEEL WEBSITE : https://rockzoneamericas.com/posts/d20-rockwheel-rapidly-removes-outcropping-limestone-then-grinds-some-large-stumps\
All of our Rockwheel cutterheads can be fitted with stump grinding bits that make short work of any sized stump.
Outfit your 18-35 TON EXCAVATOR with a Rockwheel and a set of stump picks, and you’ll have great production and a versatile attachment that can grind, demolish, trench, and remove stumps.
THIS UNIT HAS 90 MM PIN BORES AND 14.5 INCHES BETWEEN THE EARS FOR MOST 240-350 CLASS PIN GRABBER COUPLERS OR BUSH DOWN TO 80 MM PINS FOR 180-240 CLASS EXCAVATORS
THE HYDRAULIC LINES CAN BE RUN OUT THE FRONT OR BACK OR SIDE OF THE GRINDER AS YOU WANT.
The Rockwheel is powered by the standard auxilliary hydrualic kit of the excavator and installs like a hammer with a simple two line system plus case drain.
With a peak torque of over 13,000 ft lb, the Rockwheel was very affective and makes quick work of the STUMP OR TREE removal with installed set of wood cutting teeth and removes large diameter stumps.
NEW COST ON THESE UNITS IS OVER $90,000.00 - TAKE THIS UNIT FOR $15,000.00
LOCATED OUR YARD CAMBRIDGE NARROWS NB WE CAN SHIP QUICKLY AND WE GET GREAT RATES OR SHIP ON YOUR ACCOUNT
FRANK 604-476-7777 OR TOLL FREE 1-(833) 693-9323
| Construction – Brand / Manufacturer | Other |
| Construction – Model / Part Number | ROCKWHEEL 95 HYD HP HYDRAULIC EXCAVATOR TWIN DRUM STUMP GRINDER |
| Construction – Operating Hours | 99 |
| Construction – Condition | Refurbished |
| Construction – Location | Cambridge Narrows NB |
| Construction – Fuel / Power Type | Diesel |
| Construction – Technical Specifications | 15000 Ft Lb Torque |
| Construction – Attachment – Compatible Machine Type | Excavator |
| Construction – Attachment – Pin Size | 90 mm |
| Construction – Attachment – Weight | 2500 |
| Construction – Attachment – Width | 48 |
