ROCKLAND EA100 V-BOTTOM / FROST / SHALE / SANDSTONE / RIPPER BUCKET 400–550 Class Excavators
Posted Date: May 6th, 2026 at 11:38 AM
5.0 stars 243 views
Price: $10000.00
 ROCKLAND EA100 V-BOTTOM / FROST / RIPPER BUCKET
450–550 Class Excavators
💥 CONDITION & VALUE
  • As New Condition  JUST PROFESSIONALLY SANDBLASTED AND PAINTED IN BLACK CAT PAINT
  • Replacement Cost: ~$22,000 USD
  • Asking Price: $10,000 CDN
⚙️ COMPATIBILITY
  • CAT 345 – 352
  • VOLVO EC360 – EC480
  • Can be easily modified to fit any 350–550 class excavator
  • Compatible with pin-on or pin-grabber systems
🪨 PERFORMANCE
  • Makes quick work of:
    • Shale
    • Sandstone
    • Hardpan
    • Frost
  • Excellent capacity with aggressive penetration
🏗️ FEATURES
  • Constructed entirely from AR400 lightweight, high-strength, abrasion-resistant alloy steel
  • V-Bottom design for superior performance in:
    • Frozen ground
    • Caliche
    • Limestone
    • Fractured or compacted soils
  • Special teeth & adapters with points for enhanced digging
  • Case-hardened pins installed
  • Teeth are as new
  • Includes lift eye
🔧 ADCO HENSLEY V-BOTTOM RIPPER BUCKETS
400 Class Excavators (Qty: 2)
💥 CONDITION & VALUE
  • As New Condition
  • Replacement Cost: ~$22,000 USD each
  • Asking Price: $8,000 CDN  each
    (or $10,000 USD each depending on configuration)
⚙️ SPECIFICATIONS
  • 400 Class
  • 100 mm pin-on system
  • Pins not included
🪨 PERFORMANCE
  • Designed for:
    • Shale
    • Sandstone
    • Hardpan
    • Hard frost
  • Proven V-Bottom design for aggressive penetration and clean digging
🏗️ HENSLEY SPECIALTY BUCKET FEATURES
  • Ideal for:
    • Utility excavation
    • Hard frost
    • Limestone & caliche
    • Fractured and compacted materials
  • Improves digging efficiency in difficult ground conditions
Construction – Brand / Manufacturer Caterpillar
Construction – Model / Part Number ROCKLAND
Construction – Technical Specifications V RIPPER BUCKETS FOR SHALE SANDSTONE
Construction – Attachment – Pin Size 110 FRONT - 100 REAR
Construction – Attachment – Width 36
Construction – Attachment – Capacity 2.5
Construction – Bucket – Capacity 2.5
ALL-TRAC MACHINERY & LEASING Inc Feb 18th, 2026 at 12:17
Absolutely impressed with the Rockland EA100 V‑Bottom ripper bucket! It performs flawlessly on my 400–550 class excavator, breaking through frost, shale, and rock with ease. Built rugged and dependable, it’s durable and efficient on every job. Excellent quality and value—exactly as described. Highly satisfied and highly recommended!
