KOMATSU PC400 – PC490 ESCO® HDP Plus V Excavator Bucket Complete with (2) ESCO® Top Box Rippers - ESCO EXTREME DUTY TWIST LOCK TEETH
Posted Date: Jun 15th, 2026 at 12:54 PM
Price: $12000.00
KOMATSU PC400 – PC490 ESCO® SXDP Plus V Excavator Bucket
- SXPD Plus Construction: This version includes high-strength T-1 steel side plate reinforcements for enhanced structural integrity and durability in demanding applications.
- V-Bottom Design: The V-shape is specifically intended for difficult trenching work in hard-to-penetrate materials such as shale or frozen ground, aiding in penetration and material breakup.
- Triple Taper Design: The bucket's profile promotes faster, fuller loading and cleaner dumping, which improves productivity and reduces cycle times and fuel consumption.
- ESCO Top Box Rippers: The inclusion of two rippers allows the material to be broken up prior to excavation, reducing wear and tear on the bucket and the machine itself, which lowers maintenance costs.
- Extreme Duty Twist Lock Teeth: These use the ESCO Ultralok® system, a high-performance, two-piece tooth system that is hammerless, simplifying maintenance and ensuring excellent penetration and reliability. The specific "Extreme Duty" tooth profile is likely suited for highly abrasive and high-impact conditions.
- Compatibility: The attachment is specifically designed to fit Komatsu PC400, PC450, and PC490 series excavators, ensuring proper fitment and performance.
Bucket Overview
Extreme-duty ESCO® SXDP Plus V-shaped excavator bucket
Designed for Komatsu PC400 to PC490 class excavators
V-shaped Tiger Tooth configuration
Built for the toughest materials:
Blasted rock
Sandstone
Shale
Limestone
Coal
Extreme frost conditions
36-inch width
2+ yard capacity
Ready to work – no lead time
New Replacement Cost
New cost from ESCO (bucket + rippers): Over $35,000 USD
Additional costs:
Approximately 6 months lead time
Shipping
Tariffs
Your price for this ready-to-work setup: $12,000 CAD
Product Specifications – ESCO® SXDP Excavator Buckets
Machine class: PC400 - PC450 - PC 490 KOMATSU
DUE TO THE DESIGN OF THE ESCO EAR SYSTEM THEY CAN EASILY BE LINE BORED TO FIT ANY 400 - 550 CLASS EXCAVATOR ( Width Between Ears Has Room To Go To 18+ Inches )
ESCO® SXDP buckets are field-proven for durability and performance
Super extreme-duty plate lip bucket
Custom wear packages available for abrasive applications
Standard ESCO® Bucket Features
Tough T-1 steel plate lip
Full bottom wear runner
Strong formed beam for torsion resistance
Triple-taper basket for:
Fast, full loading
Clean dumping on every pass
One-piece side reinforcing plates for structural integrity
Market-leading Ultralok® tooth system for excellent penetration
Optional lip centre and wing shrouds for added protection
ESCO® SXDP Excavator Bucket – Features & Benefits
Cast shrouds for side wear protection
ESCO® AR400 full bottom wear runner and side wear strips
Tough T-1 side reinforcing plates
Lip and beam gussets to strengthen corners
Full cast wear protection:
Lip shrouds
Wing shrouds
Corner wear shoes
Chisel points for penetration and extra strength
Product link:
https://www.global.weir/product-catalogue/construction-attachments/excavator-buckets/esco-sxdp-buckets/
PLUS (2) ESCO® Tool Box Rippers
Product link:
https://www.global.weir/product-catalogue/construction-attachments/esco-tool-box-rippers-for-hydraulic-excavators/
ESCO® Tool Box Ripper Description
Compact hydraulic excavator attachment mounted behind the bucket
Designed to break up:
Rock
Frozen ground
Other hard-to-penetrate materials
Ideal for:
Construction
Mining
Demolition
Improves efficiency and reduces bucket wear
More versatile than large, aggressive rippers
Eliminates frequent attachment changes
ESCO® Tool Box Ripper Benefits
Breaks material prior to excavation
Reduces wear and tear on:
Buckets
Machines
Lowers maintenance costs
Improves machine availability
Manufactured from top-quality materials
Built for the toughest conditions
Ideal for occasional ripping applications
Perfect for demolition to loosen material and prevent bucket damage
Shanks are easily pinned into a permanently mounted base on the back of the bucket
Location & Availability
Bucket is located at our yard in Cambridge-Narrows, New Brunswick
Ready to ship or pick up immediately
Contact
Frank
📞 604-476-7777
| Construction – Brand / Manufacturer | ESCO |
| Construction – Model / Part Number | EXRETE DUTY RIPPING BUCKET |
| Construction – Condition | Refurbished |
| Construction – Location | Cambridge Narrows NB |
| Construction – Fuel / Power Type | Diesel |
| Construction – Technical Specifications | Extre Duty V Trenching and Buld Digging |
| Construction – Attachment – Compatible Machine Type | Excavator |
| Construction – Attachment – Pin Size | 100 MM FRONT 100 MM REAR |
| Construction – Attachment – Weight | 6000 |
| Construction – Attachment – Width | 36 |
| Construction – Bucket – Capacity | 2.5 |
| Construction – Bucket – Width | 36 |
Thrilled with my ESCO HDP Plus V excavator bucket! The heavy‑duty design and Extreme Duty Twist Lock Teeth make digging and ripping rock and tough ground easy. It fits my Komatsu perfectly and the included top box rippers save time and effort. Outstanding performance and reliability — highly recommended!
