Is Your Power Quality Suffering Without Proper Isolation Transformers?
Posted Date: Mar 13th, 2026 at 07:38 AM
Price: $1000.00
Steptransformer.com delivers premium isolation transformers engineered for maximum safety and electrical system protection. These specialized transformers provide complete galvanic isolation between primary and secondary circuits, effectively blocking electrical noise, surges, and transients while ensuring reliable power delivery for sensitive equipment.
Available in capacities from 500 VA to 10 kVA with customizable voltage configurations spanning 110V to 480V, Steptransformer's isolation transformers serve critical applications across marine systems, railway infrastructure, chemical processing plants, power transmission networks, and precision manufacturing environments. Each unit features robust construction with high-quality copper windings and advanced insulation systems designed for long service life and minimal energy loss.
The multi-tap design allows flexible voltage selection to match specific application requirements, while maintaining tight voltage regulation between 1% to 5% to ensure consistent output despite input fluctuations. Whether you need single-phase or three-phase configurations, these transformers provide the electrical isolation necessary to protect personnel, prevent equipment damage, and eliminate ground loops in sensitive electronic systems.
Steptransformer's manufacturing expertise enables fully customized solutions tailored to your exact specifications, with primary and secondary voltage ranges extending from 0V to 690V and capacities up to 800 kVA available for specialized industrial applications. Every transformer undergoes rigorous testing to verify dielectric strength, insulation resistance, and load performance before shipment.
For critical infrastructure requiring uninterrupted power quality, Steptransformer isolation transformers represent the definitive solution for electrical isolation, noise reduction, and system protection. Contact Steptransformer.com today to configure the optimal isolation transformer for your specific operational requirements.
