Hole in One Golf vs Eagle Whats the Difference
Posted Date: May 14th, 2026 at 09:04 AM
0.0 star 55 views
Golf has many scoring terms that can confuse new players. Two of the most exciting achievements on the course are a hole-in-one and an eagle. Both are rare, both can completely change a round, and both are celebrated by golfers around the world. But many beginners still mix them up because they sound similar in terms of scoring success.
Understanding these golf terms is important if you want to follow professional tournaments, improve your own game, or simply enjoy conversations with other golfers. Once you learn the difference, scorecards and golf commentary become much easier to understand.
In this guide, we’ll explain how each score works, when it happens, why golfers celebrate them so much, and how modern tools like a golf scoring app can help players track achievements and improve their performance.
Understanding Golf Scoring Basics
Before comparing an eagle and a hole-in-one, it helps to understand how golf scoring works.
Every hole on a golf course has a “par” value. Par is the number of strokes an experienced golfer is expected to take to finish the hole. Most golf holes are:
  • Par 3
  • Par 4
  • Par 5
If a golfer finishes a hole in fewer strokes than par, they score under par. These under-par scores have special names:
  • Birdie = 1 stroke under par
  • Eagle = 2 strokes under par
  • Albatross = 3 strokes under par
A hole-in-one is different because it describes how many shots were taken to get the ball into the hole just one shot.
What Is a Hole-in-One?
A hole-in-one happens when a golfer hits the ball directly from the tee into the cup with a single shot. It is one of the rarest and most exciting moments in golf.
This achievement usually happens on par-3 holes because they are shorter than par 4s or par 5s. The golfer must combine accuracy, distance control, spin, and a little luck to make it happen.
Many golfers can play for years without ever getting one. Even professional players celebrate wildly when it happens because of how difficult it is.
The term Hole in one is often used to describe the perfect golf shot because it ends the hole immediately with just one swing.
What Is an Eagle in Golf?
Many beginners ask, What is an Eagle in Golf? Simply put, an eagle means finishing a hole two strokes under par.
Examples include:
  • Scoring 1 on a par 3
  • Scoring 2 on a par 4
  • Scoring 3 on a par 5
An eagle can happen in different ways. A golfer might hole out from the fairway, make a long putt, or reach a par 5 green in two shots and sink the putt.
While eagles are rare for average golfers, they happen more often than hole-in-ones. Skilled players and professionals score eagles regularly during tournaments.
Main Difference Between a Hole-in-One and an Eagle
The biggest difference is simple:
  • A hole-in-one describes the number of shots used on a hole
  • An eagle describes the score compared to par
A hole-in-one can also count as an eagle, but not always.
For example:
  • On a par 3, a hole-in-one equals an eagle because it is two under par
  • On a par 4, a hole-in-one would actually be an albatross
  • On a par 5, it would be four under par, which is even rarer
This is why golfers separate the two terms even though they can sometimes overlap.
Which Achievement Is More Difficult?
Both achievements are impressive, but statistically, a hole-in-one is usually considered more difficult.
Why?
Because the golfer must hit the ball directly into the cup from the tee box. That requires:
  • Perfect direction
  • Correct distance
  • Good bounce and roll
  • Favorable spin
  • Some luck
An eagle, on the other hand, can happen through multiple strong shots instead of one perfect shot.
For example, on a par 5:
  1. Long drive
  2. Accurate approach shot
  3. One putt
That sequence can produce an eagle without needing a miracle shot.
Professional golfers often score several eagles in a season, but many still wait years between hole-in-ones.
Why Golfers Celebrate Them So Much?
Golf is a difficult sport because consistency is hard to achieve. Even experienced golfers make mistakes regularly. That’s why rare moments like eagles and aces become unforgettable memories.
A hole-in-one often becomes a lifelong story golfers tell friends and family forever. Some golf clubs even display plaques or special records for players who achieve one.
Eagles also create huge excitement, especially during tournaments. They can quickly improve a player’s score and shift momentum during a round.
In professional events, a single eagle can completely change the leaderboard.
Famous Hole-in-One Moments in Golf
Professional golf history includes many legendary hole-in-one shots. Fans love these moments because they combine skill and drama in seconds.
Some famous players known for memorable aces include:
  • Tiger Woods
  • Rory McIlroy
  • Jordan Spieth
Crowds usually erupt when a player makes an ace during a tournament. Television replays, cheering fans, and emotional reactions make these moments unforgettable.
How a Golf Scoring App Helps Players?
Modern golfers increasingly use a golf scoring app to track performance during rounds. These apps do much more than record scores.
Features often include:
  • Shot tracking
  • Distance measurement
  • Statistics analysis
  • Fairway accuracy
  • Putting performance
  • Handicap calculations
Some apps even allow golfers to record special achievements like eagles and hole-in-ones automatically.
Using a golf scoring app can help beginners understand scoring patterns and identify areas needing improvement. Over time, this data can lead to smarter decisions on the course.
Tips to Increase Your Chances of Scoring an Eagle
While eagles are challenging, golfers can improve their chances with smart strategy.
Improve Driving Distance
Longer drives create shorter approach shots, especially on par 5s.
Practice Approach Accuracy
Getting the ball close to the hole creates more eagle opportunities.
Focus on Putting
Many eagles are completed with confident putts from medium range.
Play Smart on Par 5 Holes
Par 5s offer the best eagle chances for most golfers because they are reachable in fewer shots.
Track Performance
A golf scoring app can help players identify which holes offer the best scoring opportunities.
Can Beginners Score an Eagle or Hole-in-One?
Yes, beginners absolutely can achieve both.
In fact, some beginners make hole-in-ones before experienced golfers do. Since an ace involves some luck, it can happen unexpectedly.
Eagles are slightly more skill-based because they usually require multiple strong shots. However, beginners can still score them with good contact, smart course management, and a little confidence.
Golf is unpredictable, which is part of what makes it exciting.
Final Thoughts
Golf scoring terms may seem confusing at first, but learning them makes the game much easier to enjoy. An eagle means finishing a hole two strokes under par, while a hole-in-one means completing a hole with a single shot.
The term Hole in one remains one of golf’s most celebrated achievements because of its rarity and excitement. Meanwhile, understanding What is an Eagle in Golf? helps players appreciate one of the sport’s best scoring accomplishments.
Whether you are watching professionals or playing weekend rounds with friends, knowing these scoring terms adds a deeper understanding of the game. And with the help of a golf scoring app, players today can track every memorable moment more easily than ever before.
FAQs
  1. Is a hole-in-one always an eagle?
No. A hole-in-one is only considered an eagle on a par-3 hole. On a par 4, it counts as an albatross because the score is three under par.
  1. What is an Eagle in Golf?
An eagle means finishing a hole in two strokes under par. For example, scoring 3 on a par 5 or 2 on a par 4 is called an eagle.
  1. Which is rarer: an eagle or a hole-in-one?
A hole-in-one is generally rarer because the ball must go directly into the cup from the tee shot in a single swing.
  1. Can beginner golfers score an eagle?
Yes, beginners can score an eagle, especially on shorter par-5 holes. Good shots, smart decisions, and some luck can create the opportunity.
  1. Do professional golfers get hole-in-ones often?
Professional golfers are more skilled, but hole-in-ones are still rare even at the highest level of golf.
