GX70 Hydraulic Breaker by Gorilla Hammers – More Power, Same Precision!
Posted Date: Jun 8th, 2026 at 06:31 PM
🚧 Upgrade to the GX70 Hydraulic Breaker – Built Tough by Gorilla Hammers! 🚧
Take on demanding jobs with the GX70 Hydraulic Breaker from Gorilla Hammers, designed for maximum power, precision, and durability. Whether you're working on trenching, foundation projects, or medium-duty demolition, this breaker delivers unmatched performance while ensuring smooth and efficient operation.
🔩 Key Features & Specifications:
✔️ Impact Energy: 750 ft-lb – Powerful and reliable for tough jobs.
✔️ Blows Per Minute: 480-950 – Optimized for efficiency and precision.
✔️ Operating Weight: 960 lbs – Sturdy yet easy to manage.
✔️ Tool Diameter: 2.76 inches – Built for durability and strength.
✔️ Carrier Weight Compatibility: 7,700 - 15,400 lbs – Compatible with a range of excavators.
✔️ Oil Flow Rate: 10-18 GPM – Ensures smooth hydraulic performance.
✔️ Operating Oil Pressure: 1,300 - 1,850 PSI – Delivers consistent impact energy.
✔️ Noise Level: Low-noise engineering for minimal disruption.
🔹 Why Choose the GX70 Hydraulic Breaker from Gorilla Hammers?
✅ Superior Performance – Break through concrete, rock, and other materials with ease.
✅ Built to Last – Engineered for durability and long-lasting use.
✅ Versatile Applications – Ideal for trenching, excavation, and demolition work.
✅ Quiet & Efficient – Reduced noise levels for better worksite conditions.
📞 Power up your projects today! Order the GX70 Hydraulic Breaker from Gorilla Hammers now at www.gorillahammers.com 💥
this post amazing
