GEITH CAT 345 - 352 VOLVO EC330 - EC480 HYD EXCAVATOR PIN GRAB COUPLER - $6,000 (LANGLEY BC)
Posted Date: Apr 23rd, 2026 at 09:57 PM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16
0.0 star 65 views
GEITH CAT 345 - 352 VOLVO EC330 - EC480 HYD EXCAVATOR PIN GRABBER QUICK COUPLER
THIS IS THE CADILLAC OF QUICK COUPLERS OFFERS THE STRONGEST MOST VERATILE VARIABLE CENTER COUPLER AVAILABLE.
FITS JOHN DEERE 450-490 HITACHI 450 - 490 Daewoo SOLAR 400LC-V Daewoo SOLAR 420LC-V Daewoo SOLAR 450LC-V OR ANY MACHINE
CAT 345 - 352 or VOLVO EC 460 - 480
WITH 4.33 INCH OR 110MM FRONT PIN DISTANCE BETWEEN EARS IS 18.32 REAR PIN IS 3.94 INCH OR 100MM WITH 23.11 CENTER TO CENTER
WHICH ALSO FITS VOLVO EC330B OR VOLVO EC360B
MOST CAT AND VOLVOS EXCAVATORS HAS THE CIRCUIT AND PLUMBING ALREADY INSTALLED
TAKE EITHER ONE FOR $6000.00
COUPLER IS AT MY HYDRAULIC SHOP BORETECH HYDRAULICS IN ABBOTSFORD WHO JUST REBUILT THE HYDRAULIC CYLINDER AND LINE BORED THE BORES TO MAKE SURE THEY ARE PERFCT WHICH THEY ARE
ALSO HAVE AN EXTREME DUTY 5 YARD V BUCKET THAT WAS JUST TOTALLY REBUILT TO FIT THIS COUPLER SAT NAHANNI TRCUK AND TRAILER LOGAN AVE LANGLEY - (SEE MY OTHER ADDS) TO FIT THESE COUPLERS
https://youtu.be/96gPCM6SPJo
Get the best and Safest Coupler on the market today.
With our long standing tradition Geith Couplers are accepted worldwide as the benchmark for Safety, Adaptability and Durability and comply with all European and National safety regulations.
* Available from 1 – 85t
* EN 474-1 & ISO 13031 Compliant
* Front & Rear Safety Lock
* High Strength Steel
* Low Maintenance – No Greasing Points
Description Features & Benefits
• Available for 2 – 65 ton excavators
• ISO13031 Compliant Quick Coupler
• Variable pin centre design
• Proven technology exceeds current safety standards
• Durable, compact design minimises tip radius extension
Safety & Versatility
Safety • Front & Rear Safety Locks backed up by two powerful springs which retains the attachment rear pin in case of cylinder failure
• Powerful spring activated safety locks work in all dirty environments unlike gravity systems
Versatility
•CHANGE BUCKETS FROM THE OPERATORS SEAT IN SECONDS
Construction – Brand / Manufacturer Geith
Construction – Model / Part Number GEITH CAT 345 - 352 VOLVO EC330 - EC480
Construction – Location Langley BC
Construction – Technical Specifications 350 - 500 CLASS EXCAVATO
Construction – Attachment – Pin Size 110 mm front 100 mm rear
Construction – Attachment – Weight 1531
Construction – Attachment – Capacity 110000
