EN Triple-certified Safety Storage Cabinets
Posted Date: Apr 14th, 2026 at 11:11 PM
0.0 star 108 views
Price: $6995.00
Flammable storage cabinets designed to meet the European Standard EN 14470-1 are the ideal choice for remote locations without quick access to emergency fire-fighting services, high-occupancy sites, and high-value asset environments. If you need an EN 14470-1 safety cabinet, these units are built for demanding workplaces where certified fire protection and compliant chemical storage matter most.
These triple certified safety storage cabinets are rigorously tested and certified according to EN 14470-1, FM 6050, and UL/ULC 1275 standards. They also meet NFPA 30, NFPA 1 Fire Code, and OSHA requirements, making them a dependable NFPA compliant safety cabinet solution for laboratories, industrial sites, manufacturing facilities, and research environments. For buyers comparing certified options, these cabinets combine the benefits of an FM approved safety cabinet and a UL listed flammable cabinet in one advanced storage system.
Asecos cabinets deliver outstanding protection as a 90 minute fire rated flammable cabinet and a dependable fire resistant chemical storage cabinet for hazardous liquids and chemicals. They are available in a range of heights and widths, which allows easy integration into both new and renovated laboratories or workplaces. The wide choice of interior layouts and innovative drawer systems provides the right solution for different storage needs, including use as a best cabinet for flammable liquids storage in safety-focused environments.
All cabinets feature self-closing and self-sealing doors, along with vent connections that activate under fire conditions. This makes them a reliable long-term choice for facilities that need advanced flammable liquid protection. For organisations looking to buy EN 14470-1 safety cabinet models or source a flammable liquid storage cabinet Canada, these cabinets offer certified performance, fire resistance, and peace of mind.
CapacityWidthDepthHeightDoor TypeNo. of ShelvesModelWeight (LBS.) Price
24 gal23.5 in24 in77 in1 Dr – Self Close3Q90-600355 $     6,995.00
45 gal47 in24.5 in77 in2 Dr – Self Close3Q90-1200650 $     8,850.00
Industrial Service Type Other
Industrial Industry Focus Industrial
Industrial Response Time 24–48 Hours
