EMGLO WHEELBARROW 3 HP 2 STAGE 200 PSI DEWALT PUMP PORTABLE COMPRESSOR
Posted Date: Jun 11th, 2026 at 11:21 AM
Price: $750.00
FOR SALE: EMGLO WHEELBARROW AIR COMPRESSOR – COMMERCIAL GRADE – LOW HOURS
🔥 Built for Demolition Sites – Fully Upgraded & Ready to Work
Make/Model: EMGLO with New DEWALT 2-Stage 200 PSI Pump (Pump alone retails for $1,100 USD / $1,500+ CAD)
Motor: 3 HP, 220V Single Phase, Induction Motor (Newer unit)
Airflow: 15 CFM @ 90 PSI / 11.5 CFM @ 200 PSI
Max Pressure: 200 PSI
Tank Capacity: 7.8 Gallon Wheelbarrow Style
Pump Type: Cast Iron, Oil-Lubricated, 2-Stage Piston Pump
Duty Cycle: Full Continuous Duty – Built for Jobsite Toughness
Voltage/Current: 240V AC / 13.5 Amps – Plug-and-play with cord and plug included
Dimensions: 42.5” L x 18.25” W x 24.75” H
Weight: Approx. 150 lbs
Noise Level: 85 dBA
Outlet Size & Type: 3/8” and 1/2” NPT, Female
💪 Built Tough – Not Chinese Junk
Purpose-Built: Designed specifically to meet the high-pressure needs of demolition and on-site trades
Powerful Output: Runs 5 framing guns, large air impacts, and high-demand tools
Painting-Ready: Can handle two paint guns simultaneously with steady airflow
Low Hours: Lightly used – over $3,000 CAD invested in build and upgrades
🔧 Additional Info:
Pump Life Expectancy: 5,000+ hours
Control Type: On/Off with Pilot Valve
Certified: CSA & UL Standards
🏁 Ready to Plug In & Test
Bring your hose and tools – Unit is fully functional on-site
📍 Located in BC – Owner Retiring and Leaving Province
📞 Frank: 604-476-7777
I’m extremely satisfied with the EMGLO Wheelbarrow 3 HP 2-Stage 200 PSI Dewalt Pump Portable Compressor — powerful, reliable, and perfect for heavy duty jobs. It starts easily, runs smoothly, and delivers excellent air pressure. Built sturdy and portable, it’s great for construction and workshop use. Highly recommend this compressor!
