EALITA Forklift Bucket Hydraulic Grapple Farm Tractor / Loader
Posted Date: Jun 9th, 2026 at 04:22 PM
5.0 stars 547 views
Price: $3000.00
High-Quality Steel Grapple Bucket
This premium steel grapple bucket is 64 inches wide with a capacity of 2 yards. It is designed for use with farm tractor loaders, large skid steers, RTLH machines, and can be modified for use with an excavator.
Versatile Applications
Ideal for various tasks such as feedlots, hay handling, and clearing, this bucket is a versatile tool for your needs.
Pricing and Features
Purchase this bucket with the grapple for $3,000. It includes forklift pockets for easy attachment and use with forklifts.
Hydraulic Dumper
Inside the bucket, a hydraulic dumper can be mounted on any forklift mount, offering a complete dump solution with a 90-degree dumping angle. Originally a $5,000 option, it adds significant value and functionality.
Location and Shipping
Located in our yard in Cambridge Narrows NB , we offer quick shipping at competitive rates.
Contact Information
For more details, contact Frank at 604-476-7777. Visit our website for further information.
Durability and Design
Constructed from high-strength steel plates, this bucket ensures durability and secure cargo during transshipment. It features a slip-on installation design with fixed bolts for easy attachment to the original forklift fork.
Grapple Features
Equipped with four high-strength steel claws, the grapple securely holds cargo, minimizing the risk of falling during handling.
Please consult the forklift manufacturer to determine the actual load capacity of your loader, forklift, or attachment. Note that an additional oil circuit is required for grapple operation.
Specifications
  • Installation: Slip On
  • Number of Claws: 4
  • Claws Vertical Height: 2356mm
  • Capacity: 3000kg
  • Type: F
Mark Henry Feb 23rd, 2026 at 06:58
I recently purchased the **EALITA Forklift Bucket Hydraulic Grapple for Farm Tractor / Loader from Alltrac and I’m extremely happy with both the attachment and the buying experience. This hydraulic grapple bucket is a very solid and well-built piece of equipment that adds serious versatility to my loader/forklift. It handles everything from loose hay and debris to larger irregular materials with ease thanks to its hydraulic grapple design exactly what I needed around my property. The construction feels heavy-duty and durable, and the hydraulic grapple makes grabbing, lifting, and transporting loads much simpler and more secure than a standard bucket alone could. Having this multifunctional attachment has really improved efficiency on my projects. Highly recommend this grapple bucket and Alltrac as a trusted seller. I’m very satisfied with my purchase and would definitely buy from them again!
Feb 18th, 2026 at 23:27
fantastic... EALITA Forklift Bucket Hydraulic Grapple Farm Tractor / Loader
Fatima Mukhtar Feb 12th, 2026 at 10:39
Five stars! This Ealita hydraulic grapple is a beast on a tractor loader. It's built tough, handles heavy logs and debris with ease, and the install was straightforward. Excellent value for a farm attachment that works as hard as I do. Very satisfied with this purchase.
