CM 4740 Alum 8 Ton 20 foot Cyclone Hand Chain Hoist Hook Mounted - JUST SERVICED - CERTIFIED
Posted Date: May 26th, 2026 at 01:48 PM
0.0 star 545 views
Price: $1000.00
HAD 5 - 8 TON ( 4 ARE SOLD) AND 1 -  6 TON (SOLD) UNIT TAKE YOUR CHOICE FOR $1500.00 EACH
 TAKE THE 1 - 8 TON THAT IS LEFT FOR $1000.00
ALL UNITS IN MINT WORKING CONDTION - WELL OILED CHAINES ETC AND JUST SERVICED
CM Cyclone 646 8 Ton x 20 ft Hand Chain Hoist PDF FILE:
https://www.cmworks.com/Public/6257/Cyclone%20Hand%20Chain%20Hoist_Cat.pdf
AMAZON PRICE: https://www.amazon.com/CM-4740-Aluminum-Cyclone-Capacity/dp/B008VF5VX2
$5,666.03 & FREE Shipping  USD / EACH
ACKLANDS GRAINER  Your Price: $7,246.53 CDN / EACH
WESTERN RIGGING PRICE: https://www.westechrigging.com/cm-chain-hoist-cyclone-4740.html
Price:    $5,465.62 USD
The CM Cyclone Hand Chain Hoist features superior engineering, efficiency and durability
and is considered one of the most popular and reliable hand chain hoists ever designed.
Additional features and benefits include:
    Most interchangeability of parts in the industry
    Standard Load Limiter™ for simple, automatic overload protection
    Enclosed contoured Weston-type automatic brake for positive load control
    High-efficiency spur gearing for greater lift with minimum effort
    Rugged Hoistaloy chain for added strength and durability
    Fully machined, forged liftwheel pockets for easier lifting and smooth free chaining
    High-strength aluminum alloy castings in frame and covers
    Inspected over 75 times to meet or exceed HMI and ASME/ANSI performance and safety standards
    Standard hand chain drop is 2 feet less than lift, (example: 8 foot lift hoist has 6 foot hand chain drop)
    Lifetime warranty
    Metric rated
    Made in U.S.A.
Product Details:
Fully machined, forged lift wheel pockets for easier lifting & chaining.
 High-strength aluminum alloy castings in frames and covers.
 Inspected over 75X to meet or exceed ASME/ANSI performance and safety standards.
 Options - Chain bags, metal chain contain
Technical Specs
 Includes Standard Load Limiter Item Cyclone Hand Chain Hoist Load Capacity 16,613 lbs.
Brake Weston Style Brake Standards HMI and ASME/ANSI
Hook Opening 2-1?16" Hoist Lift 10 ft.
Pull to Lift Rated Load 89 lbs.
 Min. Between Hooks 34-1/2"
