ALLU PM200 POWER MIX SOIL STABILIZER ROTARY DRUM MIXER 20 to 30 TON EXCAVATORS Mobile Soil Stabilization Plant Cement Mixing Sludge
Posted Date: May 27th, 2026 at 03:16 PM
0.0 star 611 views
Price: $20000.00
ALLU PM200 POWER MIX SOIL STABILIZER / ROTARY DRUM MIXER – 20–30 TON EXCAVATORS 🚨
Mobile Soil Stabilization Plant – Cement Mixing – Sludge Processing – Environmental Remediation
Massive Retirement Liquidation – Rare Specialty Attachment
Price: $20,000 CAD
Shipping: Available Across Canada / USA / International
Condition: Excellent – Fully Operational
https://www.youtube.com/watch?v=yGftXQV3GGI
TURN YOUR EXCAVATOR INTO A MOBILE MIXING PLANT
The ALLU PM200 Power Mix is a specialized hydraulic mixing attachment built for contractors that need to stabilize soil, process contaminated materials, or mix cement/slurry directly onsite.
Instead of hauling material away or bringing in large stationary mixing systems, this attachment allows your excavator to handle the job directly onsite.
Perfect for:
✅ Soil stabilization
✅ Cement slurry mixing
✅ Road base preparation
✅ Environmental remediation
✅ Sludge processing
✅ Clay mixing
✅ Peat mixing
✅ Polluted soil treatment
✅ Utility infrastructure projects
✅ Land development projects
IDEAL FOR
Civil Contractors
Create hardened road base and stabilize weak soil conditions.
Environmental Contractors
Mix and treat contaminated soils directly onsite.
Pipeline Contractors
Stabilize trench walls and difficult ground conditions.
Municipal Infrastructure Projects
Excellent for roads, utility corridors, and remediation work.
Mining & Industrial Sites
Process difficult materials without moving large volumes offsite.
MACHINE COMPATIBILITY
Fits excavators in the:
  • 20–30 ton range
  • 250–350 class excavators
Compatible with:
  • 80mm pins
  • 90mm pins
Buyer should verify mounting setup.
SPECIFICATIONS
Manufacturer: ALLU
Model: ALLU PM200 Power Mix
Serial Number: 04PM200023
  • Operating Weight: 4,200 lbs
  • Transport Dimensions: 101” L x 56” W x 61” H
  • Flow Requirement: 100 L/min
  • Operating Pressure: 2500 PSI
  • Power Output: 80 KW / 108 HP
  • Maximum Working Depth: 78”
  • Hydraulic Rotation: Two-Way Rotation
WHY THIS UNIT STANDS OUT
The unique drum system mixes material in three directions simultaneously, creating highly efficient blending compared to traditional methods.
This allows operators to process:
  • Clay
  • Peat
  • Silt
  • Sludge
  • Polluted soil
  • Gravel
  • Cement mixtures
  • Problem soils
Many contractors rent specialized equipment for these projects.
Owning this unit can create a major competitive advantage for specialized civil contractors.
BUILT FOR DURABILITY
  • Solid welded steel construction
  • Replaceable wear components
  • Wear-resistant steel parts
  • Low maintenance hydraulic design
  • Quick mounting options available
WHY BUY USED?
New specialty attachments like this can be extremely expensive and often come with long lead times.
This unit gives contractors immediate access to a highly specialized attachment at a fraction of replacement cost.
PART OF A LARGE RETIREMENT LIQUIDATION
We are liquidating:
  • Crusher buckets
  • Hydraulic breakers
  • Sheet pile drivers
  • Grapples
  • Compaction equipment
  • Ripper buckets
  • Specialty demolition attachments
SHIPPING / LOADING
✅ Onsite forklift available
✅ We load your truck
✅ Fast freight quotes available
✅ USA buyers welcome
Pickup Location:
Cambridge Narrows, New Brunswick, Canada
CONTACT
AllTrac Machinery & Leasing Inc.
Frank Rayner
📞 604-476-7777
☎ Toll Free: 1-833-693-EZEAD
🌐 Ezead Media Group Inc.
🌐 www.alltrac.co
If you understand soil stabilization and remediation work — you already know how hard these units are to find at this price.
