ACE 72" Clean Up Excavator Hoe Bucket – Heavy-Duty & Ready for Work
Posted Date: Jul 25th, 2025 at 11:55 PM
0.0 star 96 views
Price: $5750.00
Wide Capacity | Durable Build | Perfect for Grading & Cleanup
🔧 Product Details:
  • Brand: ACE
  • Type: Clean Up / Ditching Excavator Hoe Bucket
  • Width: 72 inches (6 feet)
  • Mounting: Designed for excavator quick coupler or pin-on setup (confirm pin size & spacing)
  • Condition: [New or lightly used – specify]
  • Material: High-strength steel with reinforced cutting edge
Key Features:
  • Extra-wide 72" design for faster grading, ditching, and final cleanup
  • Heavy-duty wear-resistant edges for longer lifespan
  • Smooth interior for efficient dumping and reduced material sticking
  • Built for mid-to-large excavators (confirm weight class and compatibility)
  • Great for landscaping, drainage, and large-scale clean-up work
  • Final grading and site finishing
  • Moving loose material (sand, gravel, soil)
  • Ditch cleaning and drainage prep
  • Landscaping and backfilling
