$450K ONSITE CONCRETE DEMOLITION QUARRY ROCK CRUSHING PACKAGE XCENTRIC XC50 Crusher Bucket + ROCKTEC Terminator TX750 Drop Hammer
Posted Date: May 6th, 2026 at 03:40 PM
Price: $110000.00
$450K ON-SITE CRUSHING PACKAGE – HIGH PRODUCTION WITHOUT A MOBILE PLANT
This package is built for contractors who want serious crushing capability on-site — without the cost, crew, and logistics of a full mobile crushing plant.
🔧 WHAT THIS PACKAGE INCLUDES
- Xcentric XC50 Crusher Bucket
- Rocktec Terminator TX750 Drop Hammer
Designed for:
- Concrete demolition
- Quarry rock crushing
- On-site material recycling
⚙️ REAL PRODUCTION CAPABILITY
- Up to ~130+ tons per hour depending on material
👉 https://alltrac.co/product/xcentric-xc50-400-650-excavator-crusher-bucket-100-yard-per-hr/- Adjustable output sizing
- Processes rock, concrete, and wet material without clogging
- 👉 https://bossattachments.co.nz/products/xcentric/xcentric-crusher
🟦 WHY THIS PACKAGE MAKES SENSE
1. REPLACES A MOBILE CRUSHING PLANT (IN MANY JOBS)
Instead of:
- $300K–$800K+ crushing plant
- 3–4 man crew
- Low-bed transport
- Setup delays
👉 You get:
- Single excavator operation
- Immediate deployment
- Crush directly on site
2. ELIMINATES HAULING & DISPOSAL COSTS
- No trucking material off-site
- No double handling
- No dumping fees
👉 Turn waste into usable product:
- Road base
- Backfill
- Resale aggregate
3. HIGH-PERFORMANCE CRUSHING TECHNOLOGY
The Xcentric system uses:
- Inertia-powered crushing
- Circular jaw movement
- Anti-jam design
👉 More details:
https://xcentricripper.com/products/xcentric-crusher-bucket/
Result:
- Higher efficiency vs standard buckets
- Less downtime
- Handles difficult / wet material
4. LOW OPERATING COST
- Minimal maintenance (grease ~every 200 hrs)
👉 https://www.shearforce.ca/wp-content/uploads/2016/08/brochure_XC_ENGLISH-July-2016.pdf- No conveyors, screens, or secondary engines
- Runs off your existing excavator
5. BUILT FOR REAL-WORLD CONTRACTORS
Ideal for:
- Demolition companies
- Excavation contractors
- Remote job sites
- Operators tired of subcontracting crushing
⚖️ CRUSHER PACKAGE vs MOBILE PLANT
| Feature | This Package | Mobile Crushing Plant |
| Setup | Minutes | Hours / Days |
| Crew | 1 operator | 3–4 operators |
| Mobility | Move with excavator | Requires transport |
| Cost | ~$110K package | $300K–$800K+ |
| Best Use | On-site flexibility | High-volume production |
💡 BOTTOM LINE
This is not just attachments — this is a complete on-site crushing system:
👉 Break → Crush → Reuse immediately
- Reduce costs
- Increase margins
- Work independently
🚨 WHO SHOULD BUY THIS
This package is ideal if you:
- Run demolition or site work
- Handle concrete or rock regularly
- Want to eliminate:
- hauling
- dumping
- subcontract crushing
📞 FINAL NOTE
After 50+ years in excavation, trucking, and demolition, this setup was built for real-world production — not theory.
👉 Available now as part of relocation to New Brunswick.
| Construction – Model / Part Number | XC50 CRUSHER - TX750 HAMMER |
| Construction – Operating Hours | 400 |
| Construction – Condition | Refurbished |
| Construction – Location | Cambridge Narrows NB |
| Construction – Fuel / Power Type | Diesel |
| Construction – Attachment – Compatible Machine Type | Excavator |
| Construction – Attachment – Pin Size | 110 MM FRONT 100 MM REAR |
| Construction – Attachment – Weight | 14000 |
| Construction – Attachment – Width | 60 |
| Construction – Attachment – Capacity | 1 |
