2023 OKADA Factory Rebuilt 7500 ft-lb Hydraulic Hammer/Breaker 300 - 450 Class EXCAVATOR
Posted Date: Dec 17th, 2025 at 10:16 AM
Price: $40000.00
OKADA ORV7500 — Mid-Class Hydraulic Breaker
Factory Shop Rebuilt BY Okada Factory
* Location: Camnbridge Narrows, NC (Ships directly from our yard or pickup)
* Price: $40,000.00 CAD
o New unit price from Okada: $105,000.00 CAD (approx.)
Key Features & Condition
* 2020 model, purchased in 2020
* Fully rebuilt in Oct 2023 (now considered a 2024 unit after Stage 2 rebuild)
* Complete rebuild performed at Okada’s Oregon factory
o Cost of rebuild: $27,000.00 USD / $37,000.00 CAD
* Rebuild includes:
o All new bushings
o New seal kit
o New piston
o 2 Moil Points:
+ 1 brand new original Okada moil point
+ 1 slightly used original Okada moil point
o Resealed at Okada factory repair shop
+ Light use prior to COVID, resealed due to sitting idle
o New nitrogen charge for optimal performance
Ready to Work
* Okada ORV7500 hydraulic demo hammer / breaker / chisel attachment tool
* Low-hour 7500 ft-lb hammer — used for only one job before COVID
* Factory-tested & certified rebuild
* Invoice available (see image #3)
* Shipped on our account for fast service & great freight rates or ship on your account
Why Choose the Okada ORV7500?
* Auto-lube system: easily adaptable to most automatic lubrication setups
* Main valve: internal control valve system increases impact energy & keeps temperatures lower
* Large capacity accumulator: reduces shock load in the system
* Stroke adjuster: variable speed control maximizes productivity
* Original holding system: secure powercell placement reduces recoil
* Larger N₂ gas chamber: ensures high-impact power
* Long stroke piston: boosts impact power while reducing vibration & recoil
* Dual chisel retaining pin: heavy-duty pins extend service life
* Durable breaker bracket: heavy-duty bottom plate for noise & vibration reduction
Technical Specifications
* Impact Energy Class: 7,500 ft-lb / 10,170 Joules
* Operating Weight: 5,950 lbs / 2,698 kg
* Oil Flow: 63–72 gpm / 238–272 lpm
* Frequency:
o L-Mode: 230–400 bpm
o S-Mode: 270–470 bpm
* Operating Pressure: 2,320–2,600 psi / 157–180 bar
* Mechanical Energy:
o Range: 98–133 HP / 73.4–99.5 kW
o Average: 115.5 HP / 86 kW
* Dimensions & Tooling:
o Unit working length: 124 in / 315 cm
o Tool diameter: 6.1 in / 155 mm
o Tool working length: 30.2 in / 767 mm
* Noise Level: 85 dB(A) at 119–167 ft / 36–51 m
* Carrier Weight Range:
o 60–92,000 lbs / 27–42 metric ton
Note: Just had 2 new quality 100 mm pins installed for the following spacings:
Distance between the ears: 16.75 inches
Center to center on pins: 23. inches
Contact
* Frank
* Phone: 604-476-7777
| Availability | For Sale |
| Mount Type | Pin-on |
| Impact Energy (ft-lb) | 7500 |
| Carrier Compatibility | Large Excavator |
| Type | Hydraulic Hammer |
| Company/Maker Website | https://okadaamerica.com/en/orv7500H |
| Price Range | 40000.00 |
| Certifications | CE |
| Location | Cambridge Narrows NB |
| Operating Weight | 25–50 Ton |
| Condition | New |
| Year | 2022 |
| Model | 2024 |
| Brand Name | OKada America |
FANTACTIC!! 2023 OKADA Factory Rebuilt 7500 ft-lb Hydraulic Hammer/Breaker 300 - 450 Class EXCAVATOR
