2015 Caterpillar D10T (Finning zero hour rebuild)
Posted Date: Sep 15th, 2024 at 09:32 AM
3.0 stars 0.9K views
Price: $1750000.00
Finning Zero Hour Rebuild
A Finning Zero Hour Rebuild is when a machine undergoes a total rebuild by Finning, essentially making it brand new.
Want to know more? Click herehttps://www.finning.com/en_CA/services/rebuilds/certified-rebuilds%C2%A0
Specifications:
 * 1200 hours since rebuild
  * Single shank ripper
Dimensions:
    * Ground Clearance: 2 ft (1 m)
    * Height - Top of Cab: 13 ft (4 m)
    * Length of Track on Ground: 13 ft (4 m)
    * Length with Blade: 30 ft (9 m)
    * Length without Blade: 18 ft (5 m)
    * Width Over Tracks: 10 ft (3 m)
Engine:
    * Aspiration: Turbocharged
    * Bore: 5 in (14 cm)
    * Displacement: 1,648 cu in (26,998 cu cm)
    * Engine Model: Cat C27 ACERT
    * Flywheel Power: 580 hp (433 kW)
    * Gross Power: 661 hp (493 kW)
    * Make: CAT
    * Model: C27 ACERT
    * Net Power: 580 hp (433 kW)
    * Number of Cylinders: 12
    * Power Measured at: 1800 rpm
    * Stroke: 6 in (15 cm)
Hydraulic System:
    * Pump Flow Capacity: 107 gpm (405 lpm)
    * Pump Type: Gear-driven
    * Relief Valve Pressure: 2725 psi
Operating Specifications:
    * Alternator Supplied Amperage: 95 amps
    * Cooling System Fluid Capacity: 35 gal (132 l)
    * Engine Oil Capacity: 18 gal (68 l)
    * Final Drives Fluid Capacity: 6 gal (23 l)
    * Fuel Capacity: 318 gal (1,204 l)
    * Hydraulic Fluid Capacity: 38 gal (144 l)
    * Operating Voltage: 24 volts
    * Operating Weight: 146,500 lbs (66,451 kg)
Service Refill Capacities:
    * Fuel Tank: 318 gal (1,204 l)
Standard Blade:
    * Capacity: 24 cu yd (19 cu m)
    * Height: 81 in (206 cm)
    * Width: 16 ft (5 m)
Transmission:
    * 1st Gear Forward: 3 mph (4 km/h)
    * 1st Gear Reverse: 3 mph (5 km/h)
    * 2nd Gear Forward: 5 mph (7 km/h)
    * 2nd Gear Reverse: 6 mph (9 km/h)
    * 3rd Gear Forward: 8 mph (13 km/h)
    * 3rd Gear Reverse: 10 mph (16 km/h)
    * Max Speed Forward: 8 mph (13 km/h)
    * Max Speed Reverse: 10 mph (16 km/h)
    * Number of Forward Gears: 3
    * Number of Reverse Gears: 3
    * Transmission Type: Power shift
Undercarriage:
    * Ground Contact Area: 7,326 sq in (120,052 sq cm)
    * Number of Shoes per Side: 44
    * Number of Track Rollers per Side: 8
    * Standard Shoe Size: 24 in (61 cm)
    * Track Gauge: 8 ft (3 m)
    * Track Pitch: 10 in (26 cm)
