1993 Grove RT528C Rough Terrain Crane
Posted Date: Jul 8th, 2025 at 10:58 PM
0.0 star 171 views
Price: $49900.00
🏗️ 1993 Grove RT528C Rough Terrain Crane
Powerful 28-Ton Capacity | Rugged Mobility | Trusted Grove Reliability
🔧 Crane Specifications – Grove RT528C
  • Model: Grove RT528C
  • Lifting Capacity: 28 tons (56,000 lbs) maximum lifting power
  • Boom:
    • Hydraulic telescopic boom
    • Approximate length: 58 ft extended reach
    • Optional jib extension available for increased height and reach
  • Boom Reach:
    • Horizontal reach up to 50+ ft for versatile lifting tasks
    • Vertical reach suitable for multi-story construction and industrial applications
  • Rotation: 360° continuous hydraulic slew for full jobsite coverage
  • Outriggers:
    • Heavy-duty hydraulic outriggers with adjustable extension for maximum stability
    • Designed for setup on uneven and rough terrain
  • Controls:
    • User-friendly hydraulic joystick or lever controls for smooth operation
    • Precise boom and load management
🛠️ Engine & Mobility
  • Engine: Diesel-powered, Tier 2 or Tier 3 compliant (confirm specific model year)
  • Drive: 4WD rough terrain chassis for excellent maneuverability on challenging sites
  • Steering:
    • Multiple steering modes including 4-wheel and crab steering for tight spaces
  • Travel Speed: Approximately 15-20 mph for easy movement around large sites
  • Suspension: Heavy-duty suspension system for shock absorption and stability
🔩 Key Features & Benefits
  • Combines high lifting capacity with excellent rough terrain mobility
  • Compact design allows operation in tight jobsite conditions
  • Quick hydraulic setup with stable outriggers improves efficiency and safety
  • Durable construction built for long-term use in harsh environments
  • Low maintenance requirements with good parts availability
Ideal Applications
  • Heavy construction and infrastructure projects
  • Steel erection and structural lifts
  • Utility and municipal work
  • Oil and gas field lifting
  • Rental equipment fleets
📦 Condition & Availability
  • Year: 1993
  • Hours: [Insert operating hours] – well maintained and serviced
  • Tires: Good condition suitable for rough terrain
  • Hydraulics: Leak-free and fully operational
  • Title: Clean and clear ownership
💰 Pricing & Financing
  • Competitively priced based on condition and market demand
  • Nationwide delivery and setup assistance offered
  • Trade-ins welcome
🔧 Why Choose the Grove RT528C?
  • Trusted Grove brand known for durability and performance
  • High capacity rough terrain crane with versatile boom options
  • Reliable hydraulic system and smooth controls
  • Excellent choice for contractors and rental fleets needing a workhorse crane
