EMGLO WHEELBARROW 3 HP 2 STAGE 200 PSI DEWALT PUMP PORTABLE COMPRESSOR - $1,000
4.0 stars
Price: $1,000 Negotiable
Oil Lubricated, 7.8 gal, Wheelbarrow, 3 hp, 14 cfm @ 90 psi 11.5 CFM @200 PSI
WE BUILT THIS TO HAVE A WHEELBARROW COMPRESSOR ON DEMOLTION SITES THAT REQUIRED HI-PRESSURE
WE HaVE OVER $3000.00 INVESTED IN THIS LOW HOUR  UNIT WITH THE NEW DEWALT PUMP NEW 3 HP AC 220 VOLT SINGLE PAHSE MOTOR ETC
https://www.toolservicenet.com/dewalt/en/c//p/P5130240-00
RETIRING AND LEAVING BC
THIS WILL RUN 5 FRAMING GUNS - LARGE AIR IMPACTS - STEADY AIR FOR BLOWING DUST AND MANY MORE USES
WILL RUN TWO PAINT GUNS STEADY
Product Details
EMGLO WHEELBARROW 3 HP 2 STAGE 200 PSI DEWALT PUMP Portable Air Compressor
FULL CONTINOUS DUTY AMERICAN BUILT COMMERCIAL UNIT - NOT CHINESE JUNK
Oil Lubricated, 7.8 gal, Wheelbarrow, 3 hp, 15 cfm @ 90 psi 11.5 CFM @200 PSI
WE BUILT THIS TO HAVE A WHEELBARROW COMPRESSOR ON DEMOLITION SITES THAT REQUIRED HI-PRESSURE
WE HAVE OVER $3000.00 INVESTED IN THIS LOW HOUR UNIT WITH THE NEW $1500.00 CDN 2 STAGE 200 PSI DEWALT PUMP NEW 3 HP AC 220 VOLT SINGLE PHASE MOTOR ETC
WILL RUN TWO PAINT GUNS STEADY FOR ON SITE PAINTING - THIS UNIT IS READY TO WORK CAN BE PLUGGED IN AND TESTED - JUST BRING YOUR TOOL AND HOSES
Product Details
Brand:  EMGLO WITH NEW DEWALT 2 STAGE 200 PSI PUMP -  PUMP PRICE IS $1100.00 USD
Average Pump Life 5,000 + hr
Control Type MANUAL On/Off - PRESSURE REGULATED OFF/ON
Current Rating 13.5 A 220 SINGLE PHASE
Cylinder Material Cast Iron
Duty Cycle Continuous
Electrical Connection 220 VOLT SINGLE PHADE Cord with Plugs
Free Air Flow Rate @ 90 psi 14 cfm
Input Voltage 240V AC
Lubrication Type Oil Lubricated
Maximum Operating Pressure 200 psi
Maximum Speed 1,725 RPM
Motor Type Induction
Number of Cylinders 2
Number of Stages 2
Outlet Gender Female
Outlet Size 3/8 in - 1/2 INCH
Outlet Type NPT
Output Power 3 hp
Overall Height 24.75 in
Overall Length 42.5 in
Overall Width 18.25 in
Pump Type Piston
Sound Level 85 dBA
Standards CSA; UL
Tank Size 7.8 gal
Tank Style Wheelbarrow
Valve Type Pilot
Weight 200 lb
Company Jenny Emglo Compressors
Website To Display Url https://www.centralaircomp.com/emglo-compressors
Anonymous Jul 11th, 2024 at 06:58
good and effective product
