DEMO HINIKER MODEL: 2853 SNOW PLOW MOUNTS - CONTROLS - MANUALS -
Price: 3500.00
MODEL: 2853 - Snow plow - NEW DEMO PLOW COMPLETE WITH CONTROSL - MANUALS - TRUCK MOUNTING SYSTEM - NEW COST $10,000.00 CDN
BEST US DEALER PRICE IS $ 6199.00 USD ($8504.69 CDN) PLUS SHIPPING AND CUSTOMS TAXES ETC = $10,000.00 CDN PLUS TIME TO GET
SEE WEBSITE : https://www.smouse.com/new-hiniker-8-NG5g.html
TAKE IT NOW - FOR $3500.00 THE PLOW IS COMPLETE BUT MISSING 1 HEAD LIGHT WHILE BEING TRUCKED AND HAS A CRACKED OIL TANK
WE WERE TOLD AND IT WAS SOLD TO US TO FIT A FORD 4 X 4 PICKUP AND WERE ADVISED IT WAS A NEW DEMO PLOW
THE ONE IN THE PICTURES IS THIS EXACT PLOW YOU WILL GET
SPECS;
BLADE WIDTH 8 1/2
BLADE HEIGHT 30
GAUGE OF STEEL 12GA
VERTICAL RIBS 8
COMPRESSION TRIP SPRINGS 4
PLOW WIDTH @ 31 DEGREE ANGLE 87
CUTTING EDGE (HIGH CARBON 1084 STEEL) 38 x 6
POWER ANGLING RAMS 1 12 x 10
WEIGHT (NET OF TRUCK MOUNTED HARDWARE) 649 lbs.
Heavy-Duty Full-Trip Steel Plow 2000 Series Snowplows Take a Professional Approach to Snow Removal!
Hiniker 2000 Series full-trip snowplows use box section frames and heavily reinforced moldboards for strength and durability. 30 inch tall high-curve moldboards move heavy snowfalls quickly.
Our hydraulic scissors lift reduces transport bounce and bang.
Convenient compact joystick controls can be mounted anywhere or held in the palm of your hand.
And the Hiniker Quick-Hitch mounting system is one system that truly lives up to its name.
Count on Hiniker's proven performance--the professionals choice!
THIS IS LOCATED IN CAMBRIDGE NARROWS NEW BRUNSWICK - I BOUGHT IF FOR MY NEW HOME BUT ENDED UP WITH A SNOW BLOWER DUE TO THE LANDSCAPING OF THE HOME
PRIVATE SALE NO TAXES - CASH OR ETRANSFER ONLY SALE
EMAIL ME FOR DEALER PRICE LIST - MANUALS AND PARTS MANUAL IN PDF FORMAT
FRANK 604-476-7777 \ The Hiniker Model 2853 Snow Plow is a specific type of snow removal equipment manufactured by Hiniker Company, which is known for producing a variety of snow plows and agricultural equipment. While I can provide general information about what you might expect from a snow plow like the Hiniker 2853, for the most detailed and accurate information, it's always best to refer to the manufacturer's documentation or contact Hiniker directly.
Here are some typical features and aspects you might find in a snow plow like the Hiniker 2853:
Plow Type: The model number (2853) suggests that it might be part of a series of plows designed for specific types of vehicles or snow removal tasks. It could be a straight blade or a V-plow, each suited for different plowing needs.
Size and Weight: The dimensions of the plow (width, height) and its weight are crucial for determining which vehicles it can be attached to and what kind of snow load it can handle.
Mounting System: Hiniker snow plows often come with a quick-hitch mounting system, which allows for easy attachment and detachment from the vehicle.
Construction and Material: The plow is likely made of high-strength steel or another durable material to withstand the rigors of snow plowing, including impact with ice and frozen ground.
Blade Features: Features like trip edges, adjustable skid shoes, and hydraulic angling might be present. These features help protect the plow and vehicle from damage and improve plowing efficiency.
Hydraulic System: The plow may use a hydraulic system for lifting, lowering, and angling the blade, which requires compatibility with the hydraulics of the vehicle it’s mounted on.
Compatibility: It’s important to ensure that the plow is compatible with the intended vehicle, both in terms of size and hydraulic/power requirements.
Applications: Designed for snow removal, it could be used in various settings such as residential driveways, commercial parking lots, or municipal roads, depending on its size and capabilities.
Safety and Maintenance: As with any heavy equipment, proper maintenance is key for safe and efficient operation. This includes regular checks of hydraulic systems, mounting hardware, and the physical condition of the blade.
Remember, operating a snow plow requires skill and attention to safety, both for the operator and those around the plowing area.
Training and adherence to safety guidelines are important. For specific operational techniques, maintenance guides, and safety instructions, consulting the user manual or getting in touch with Hiniker or a professional dealer is advised.
Contact me to send both the factory installation and repair and parts manual that we have in PDF format.
okayndbdjsnndn
