Menu
Quick Eze Links
CUSTOM BUILT LW 48 INCH IN-SITU REMEDIATION STIRRING BLENDER 20-40 TON CLASS EXCAVATOR
Posted Date: Feb 8th, 2025 at 04:12 PM
0.0 star
Price: 30000.00
**Applications:**
- Organic compost and waste mixing
- Soil blending
- Contaminated soil remediation
The LW48M effectively incorporates material into a slurry for various applications, including chemical and petroleum remediation and bioremediation.
The LW 46M ID is used for stirring a containment pond mixed with soil, water, and byproducts from the petroleum industry.
Rated for continuous underwater operation, the stirrer is a unique and effective solution for remediation projects of any scale.
**In-Situ Bioremediation Equipment:**
Used to treat contaminated soil or groundwater without moving the contaminated material.
- Bioreactors, stirrers, and other devices create an environment where microorganisms break down contaminants.
**Examples of In-Situ Bioremediation Equipment:**
- *In-situ bioreactors:* Treatment cells containing organic material and amendments to create an anaerobic environment.
- *Aerobic bioventing:* Injects air into the subsurface to enhance aerobic metabolism of hydrocarbons.
- *LW48M Stirrer:* Incorporates material into a slurry for remediation projects.
In-situ bioremediation is a cost-effective method as it avoids excavation expenses.
**General Specifications:**
- 48" stirring depth (standard model)
- 48" stirring diameter (standard model)
- Continuous underwater and above-ground operation
- Sealed rotec bearing assembly for long-term use (10,000+ hours)
- Quick change pin grabber mounting for 80 or 90 mm pins
- Self-purging grease system
- Rotating hub debris guard
- Adjustable speeds with variable hydraulic flow from the excavator's auxiliary hydraulic circuit
- No modification needed to the excavator boom geometry
- Existing power plant operates at slow to full speed
- Adaptable for 40,000 to 90,000-pound excavators
**Watch the Video:**
Watch a similar blender in action.
**Pricing:**
Originally priced at **$65,000.00 USD ($92,000.00 CAD)**, now available for **$30,000.00 USD**. No waiting time – ready to work now!
Contact: **Frank - 604-476-7777**
**Benefits of In-Situ Remediation:**
- **Cost:** Up to 75% less expensive than excavation and off-site disposal
- **Time:** Faster and more effective than traditional methods like pump and treat
- **Space:** Requires less above-ground space while treating a larger subsurface area
- **Disruption:** Minimal impact on site operations
- **Sustainability:** Lower carbon footprint and minimal secondary waste
- **Health:** Reduced risk of human exposure to contaminants
**Example Use Case:**
- Application of In-Situ Chemical Oxidation (ISCO) technology at a former dry cleaner site
- Target: Reduction of chlorinated volatile organic compounds (cVOCs), particularly PCE, from >20 ppm to <5 ppb
- Project designed into a grid with 12 sections, each 25 x 21.5 feet and 5 feet deep
- RegenOx® remediation chemistry used with an excavator for soil mixing
- After eight days, 98-100% reduction achieved
**LW 48 In-Situ Development:**
Designed, developed, and manufactured as a remediation blender for waste cell management issues.
**Uses:**
- Stirring petroleum-contaminated waste cells
- Petroleum bioremediation with treatment agents
- Waste liquid solidification by injecting powdered cement
- Cleaning oil from sand and soil
- Cleaning sediment from barges
- Managing dredged material
- Soil bioremediation
- Mixing aggregate materials like rocks and compost
- Mulching agricultural soils
- Reforestation: Breaking compacted soils for site preparation
- Humanitarian demining operations
- Dredging barge cleaning for material suction by dredge pumps
**Compatibility Table:**
- Excavator size: 20+ ton class
- Long reach 25-40 ton excavators for the LW 48M Blender
Excavator Models:
Crawler Excavators
Excavator Attachments:
Augers
Fuel Type Diesel
