Menu
Quick Eze Links
ALLU PM200 ROTARY DRUM SOILS-SLUDGE-COMPOST MIXING 200-350 CLAS
Posted Date: May 1st, 2024 at 11:57 AM
0.0 star
Price: 30000.00 Negotiable
EXCAVATOR - PERFECT FOR MIXING COMPOST OR SLUDGE OR MIXING FLAMABLES - BRUSH INTO SOIL FOR FIRE PREVENTION ETC
OR USE CEMENT SLURRY INJECTED INTO THE PROTECTED SPRAY HOSE AND NOZZLE AT THE END BETWEEN THE PADDLES AND MIX SAND - GRAVEL OR OTHER MATERIALS TO MAKE A HARD CEMENT SURFACE.
LITTLE USED UNIT - MOUNTED C/W 90 MM PINS FOR ANY 250-350 CLASS EXCAVATOR
OR BUSH DOWN TO 80 MM PINS FOR 200-240 CLASS EXCAVATORS
TAKE THIS LOW HOUR C/W FACTORY STAND FOR $30,000.00 - NEW COST OVER $100,000.00 PLUS 6 MONTHS LEAD TIME
SEE THE VIDEOS
https://youtu.be/TiPzMbgxsgU
https://youtu.be/u-4ndeXn2cQ
DOWNLOAD OR OPEN THE ALLU PDF FILE - COPY AND PASTE :
https://www.allu.net/?post_type=allu_industry&p=2533
http://mail.ezead.com:7080/users/f.rayner/ALLU-SOIL-REMEDIATION/ALLU%20Stabilisation%20System.%20New%20concept%20for%20soil%20improvement.pdf
* Make: Allu
* Model: PM200
* BasicMachine Size - 20-30 tons
* Serial Number: 04PM200023
* Transport Dimensions: 101" L x 56" W x 61" H
* Operating Weight: 4,200 lbs
* 80 KW = 108 HP AT 100 LITRES PER MINUTE FLOW AT 2500 PSI
Features of Unit:
Designed For Durability
Easy Mounting
Mixing Of Different Materials
Specifications
Pin Diameter: 90 mm
Distance to Pins (OC): 19" to Ears (ID): 16"
Fits: Set up for any 250-350 Class Excavator
Maximum working depth: 78"
Hydraulic: Two-way Rotation
ALLU PM Power Mix is a hydraulic equipment attachments for excavators.
When ALLU Power Mix is attached to the excavator, it turns into a mobile and efficient mixing plants.
Optimum design
ALLU Power Mix is able to efficiently handle very hard materials, such as different
varieties of clay, peat, silt, sludge or polluted soil.
Mixing efficiency is calculated based on the optimal horizontal position of rollers and the unique design of mixing elements.
The rollers move and mix material in three directions simultaneously.
Processing of the material to a depth of 3 meters
ALLU Power Mix can process the material to a depth of 3 meters, depending on the
equipment of the excavator and the condition of the material.
Since ALLU Power Mix is an additional attachments, excavator can also be used to perform other operational tasks.
ALLU Power Mix is a perfect tool for both large and small amount of works to perform.
Designed for time-consuming tasks
ALLU Power Mix has a solid steel welded construction, all wear parts are made of wear- resistant steel, and can be replaced.
The radial piston motor is power-suppled by the hydraulic system of an excavator.
The rotation is transmitted to the roller through the chain drive.
The design requires minimal maintenance.
Easy to mount
ALLU Power Mix can easily be mounted on an excavator with the fingers or the quick-mounting adapter.
THIS UNIT IS ALSO SET UP TO WORK WITH THE ALLU POWER MIX FEED SYSTEM AS FOLLOW:
The ALLU PM power mix is a versatile accessory for excavators for in-situ soil stabilization.
The PM can process a variety of materials on site for a cost effective operation. With horizontal drums, the ALLU PF pressure feeder injects the binding agent beneath the ground directly to the middle of the mixing drums on the PM, guaranteeing better mixing to the base material.
The PF is a remote-controlled unit that follows behind the lead excavator. The power mix is available in three different model sizes to reach 5, 10 and 15 ft. (1.5, 3 and 4.6 m) depth.
For more information, call 800/939-2558 or visit www.allu.net.
